Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I've just upgraded to AutoCAD Architecture 18 (previously AutoCAD17) and the ribbon has changed a bit meaning some of my most used commands are now missing.
Most notably the drop-downs which quickly and easily select the linetype, line weight, etc. which used to be located just below the layer drop-down.
The only way I can find of having these options on hand is to have the properties window constantly open which just fills up my screen with a previously unused window.
Is there any way to restore the drop-down menus back to the home ribbon?
Cheers.
Solved by ntellery. Go to Solution.
Solved by David_W_Koch. Go to Solution.
The items you describe have never been part of the out-of-the-box ACA.cuix Home ribbon tab. You were either using a customized version of the ACA.cuix file, to which these controls were added, or you were using the ACAD.cuix as your main customization file, which does have those items as you noted.
This blog article describes how you can create a Properties panel of your own, and then you could choose to add it to the Home ribbon tab in the ACA.cuix file. Or, you could use the techniques covered to either add a Properties panel or to customize the Layers panel directly in the ACA.cuix file. I like to keep my customizations as separate as possible, to minimize the time needed to bring them forward to a new release, so I would create the panel in a partial customization file of my own, and only touch the ACA.cuix to add the panel. But you may prefer to do everything right in the ACA.cuix file.
I created my own menu MyStuff.cuix and added that whole tool bar from acad along with some other items. This way it's completely separate from what Adesk does with the menus and I can load it as a separate item.
Hi @patrick,
I see that @David_W_Koch and @ntellery have provided some excellent responses and recommendations here. Did either (or both) or their replies help you?
If so, please click Accept as Solution on the posts you found helpful so others in the community can find them easily in the future.
I went to the blog and could not find any info. I need the drop down menu for line types as well. The post says to create your own, but I don't know how to do that.
