AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Using Quick Trim with custom blocks
4 REPLIES 4
419 Views, 4 Replies
Hello all,
I have been piloting the use of AutoCAD 360 Mobile (Pro) using an Android (Samsung) tablet for a client that does plumbing engineering.
I have noticed that the client's previously created blocks (which can be inserted into the drawings using the blocks tool palette in AutoCAD 360 Mobile) do not interact well with the Quick Trim tool.
They have blocks, made up of basic 2D geometric shapes, which overlap 2D lines. I am trying to trim the overlapping line of out of the block's interior. But, the app does not recognize the block as lines/borders to trim around.
Has anyone else had a problem (or have a solution) to using blocks with the Quick Trim tool in AutoCAD 360 Mobile?
If more info is needed please feel free to ask.
Thank you,
DK
4 REPLIES 4
pendean
In Desktop AutoCAD (and the mobile version AFAIK) do not allow editing of block content like that.
You need desktop AutoCAD and use REFEDIT or BEDIT commands to edit content inside blocks.
in reply to: pendean
I was unclear in my description. I am not attempting to edit the blocks themselves. Rather, the blocks are placed over 2D lines. I want to trim the lines so they do not show as intersecting through the blocks
pendean
Ah! Thanks for the explanation. Sadly that's a known limitation in the mobile app.
Macro.Liu_Autodesk
The trim command doesn't work with blocks.
Thanks.
”Boost
