AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Using AutoCAD 360 Pro to edit attributes
8 REPLIES 8
Message 1 of 9
jeffHGCE
542 Views, 8 Replies
Does anyone know why AutoCAD 360 pro on Windows 10 will not allow editing of attributes? I can see the values in the properties palette, but does nothing when I try to edit them.
I had dynamic actions applied to them but also tried ones without dynamic actions.
8 REPLIES 8
Message 2 of 9
pendean
in reply to: jeffHGCE
There is no attribute editing in autocad360pro anywhere at the moment.
Message 3 of 9
jeffHGCE
in reply to: pendean
http://mobilehelp.autocad360.com/customer/portal/articles/1107410-how-can-i-edit-the-attributes-of-a...
Message 4 of 9
pendean
Well there you go, learned something new today. Thanks for sharing.
Wish it was part of the text edit tool, this method is cumbersome.
Message 5 of 9
jeffHGCE
If you look at the bottom of this article is seems to indicate that editing from the property pallet is only supported by Ios devices
http://help.autocad360.com/customer/portal/articles/1531768-how-can-i-view-and-edit-the-properties-o...
Message 6 of 9
chadp
I have found the exact same issue. I can see attributes in Properties, but cannot edit them. Also, there doesn't seem to be any support for dynamic block functions (Stretch, rotate, etc.)
I have installed and tested Autocad 360 Pro (Trial Version) on two Windows 10 machines, a Surface Pro and a Desktop with identical results.
Message 7 of 9
pendean
in reply to: chadp
No support for Dynamic Blocks in this cloud based app: are your attributes part of that or set to "hidden"?
Otherwise select the block with the attribute, click on the blue tab at the top-left, select the sliders icon which is PROPERTIES, at the bottom of the page is where you change the attribute entry.
Message 8 of 9
tirza.ben-ner
in reply to: chadp
Editing and adding block attribute are supported for Android and iOS device only, but not for Win 10 devices yet.
Dynamic blocks are not supported at all.
Tirza Ben-Ner
AutoCAD 360 Support Specialist
Message 9 of 9
Can i ask if this Issue of editing attributes in the windows tablet is being resolved, and when is it likeley to be fixed?
”Boost
