Does anyone know why AutoCAD 360 pro on Windows 10 will not allow editing of attributes? I can see the values in the properties palette, but does nothing when I try to edit them.
I had dynamic actions applied to them but also tried ones without dynamic actions.
If you look at the bottom of this article is seems to indicate that editing from the property pallet is only supported by Ios devices
I have found the exact same issue. I can see attributes in Properties, but cannot edit them. Also, there doesn't seem to be any support for dynamic block functions (Stretch, rotate, etc.)
I have installed and tested Autocad 360 Pro (Trial Version) on two Windows 10 machines, a Surface Pro and a Desktop with identical results.
Editing and adding block attribute are supported for Android and iOS device only, but not for Win 10 devices yet.
Dynamic blocks are not supported at all.
Can i ask if this Issue of editing attributes in the windows tablet is being resolved, and when is it likeley to be fixed?
