У меня опять проблема с этим продуктом😓 Но теперь проблема в том, что на компьютере я сохраняю в облако, в предлагаемую папку "automatic copy", а в приложении autocad 360 для iPad его не нахожу. При чем это работает не совсеми чертежами. Некоторые сохраняются, а некоторые он не хочет сохранять. И я не понимаю закономерность😩
Hi Liza,
Are you having trouble with accessing your files in AutoCAD 360?
If so i'll move your post over to that Forum, however, i wanted to know for sure first.
Please let me know
Here is what my translation stated below:
I have again a problem with this produktom😓 But now the problem is that I keep on the computer in the cloud, in the proposed folder "automatic copy", and annex autocad 360 for the iPad it can not find. When this does not work than sovsemi drawings. Some are saved, and some he does not want to keep. And I do not understand zakonomernost😩
У меня опять проблема с этим продуктом 😓 Но теперь проблема в том, что на компьютере я сохраняю в облако, в предлагаемую папку "automatic copy", а в приложении autocad 360 для iPad его не нахожу. При чем это работает не совсеми чертежами. Некоторые сохраняются, а некоторые он не хочет сохранять. И я не понимаю закономерность 😩
Да, с AutoCAD 360
Thanks for letting us know it is AutoCAD 360, and we will move your post to the AutoCAD 360 forum. I also think I let you know this in your other feedback as well.
"I have again a problem with this product 😓 But now the problem is that I keep on the computer in the cloud, in the proposed folder "automatic copy", and annex autocad 360 for the iPad it can not find. When this does not work than sovsemi drawings. Some are saved, and some he does not want to keep. And I do not understand law 😩
Yes, with AutoCAD 360"
Hope this helps get you pointed to the right team for help and have a great day.
Hi @smirnova_liza95,
Well, you're referring to both products- A360 Drive, and AutoCAD 360.
Best of my understanding, you're syncing drawings via the A360 Drive mapped folder on your computer Is that right?>
A360 and AutoCAD 360 should share the same storage, however and unfortunately, the sync between the 2 products is partly broken. We're well aware of that.
At this point, we recommend using AutoCAD 360 only to upload, access, view and edits files.
If you'd like to work on your files back on your computer, please try the Download option available for both our web app, and Win 10 app.
I can only suggest to you at this point, to re-upload your files directly to your AutoCAD 360 account, and let us know how it goes.
Best,
Здравствуйте
В этом приложении я не вижу своих чертежей, которые сделала на компьютере и сохранила в "облако".
What happens when you try to access your drawings via AutoCAD 360?
How were these drawings uploaded into your account?
Здравствуйте.
В основном, я не вижу их на iPad. То есть я сохраняю на компьютере в облако, но открыть на iPad их не могу. Как-то давно у меня получилось несколько сохранить, но только они открываются.
Could you please share screenshot of how you're syncing drawings to the cloud?
Once again, I believe you're using A360 Drive to store drawings, and drawings are being uploaded to A360 Drive directly from Autocad desktop.
Due to some known and severe syncing issues between A360 and AutoCAD 360, drawings that were uploaded directly to A360 Drive, may not be available within the AutoCAD 360 account.
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
