Had 10 measured floor plan drawings put on my 360 space.opened them in AutoCAD 360 and can't see any entities. Layers all came across but can't see any line work or text in model space. Zoom extents shows nothing. What is happening or what am I doing wrong.
is it because we are using the new AutoCAD 2018? As older drawings load fine
Hi Dean
Attached is a copy of one of the plans. It was created in Autocad 2108 but I have just opened and saved it in LT 2016 and then put it on my 360 drive.
It still shows no data. Please note I am opening these on my Ipad 2 with plenty of memory to spare. Drawings I already have on my drive still load fine and are bigger than this one.
When I load it directly back into my main computer from the 360 drive it loads fine
Could you take a look and see if it loads and you can look at the linework on your setup.
Cheers
Alan
I try to open it directly on iPad (now the latest iOS version supports to open dwg from email attachment directly), and the result is as attached. Is it as expected?
Yes
thats what I should be seeing.
I am using the latest IOS on my pad too.
Then probably you can delete the drawing in AutoCAD 360 first, and send this drawing as email attachment to iPad and try to open again. Hope it works.
Thanks Dean
First thing I did was zoom extents when I didn't see anything. I think I will reload the 360 app and try emailing the drawing as well as someone else suggested to see if that works. Will let you know
