PLOT settings are saved in each file ONLY, it's not a system wide default setting. Is that the actual challenge you face, or are you just not able to get that far? If the latter, see images below to get you started
Where do you find the options in which you can add viewports? for example Im creating template shapes in which I'll print out at 1:1 scale
