When I export to .pdf the scale is not correct. I've changed scales, fit to paper, etc but all I get is either a blank page or an image that fills the page. If I can't generate a plot that is the same size as what I'm drawing then this app is useless to me. What am I doing wrong?
Solved by pendean. Go to Solution.
Using Autocad 360 mobile on an ipad 2 pro. Latest version.
The drawing is one I generated using the app, not one done on another version and imported.
I have tried plotting from model and layout with same results. If I check fit to paper it fills the paper with the image. If I uncheck this and use any other scale it gives the same result which is a very small version of the drawing which does not change as I change the scale.
I've tried plotting extents and display with same results.
Ok, I have a partial solution.
Layouts 1 & 2 are at 1/2"=1'-0" scale. If you use this then they plot out to scale.
Still have not determined how to plot model space at correct scale.
