Hi @Anonymous,
The green arrow marks files that are downloaded locally, and can be opened while being offline.
What happens when you try to open the file?
We'd be happy to examine this issue, so please share with us the file's name and your username (You can do it directly by emailing us at feedback@autocad360.com).
I am having exactly the same problem.
The file comes from the architect and has some sizes but I need to know others and also certain areas.
When using the measuring tool it shows 71.71 units ( I say that because if I choose mm it says 71.71 mm, if I choose meters it says 71.71M !!).
Although it will measure an area it is not correct.
This is causing the programme to be pretty useless - and I was considering in upgrading - not at the moment though!
This is exactly the same for both PC and phone versions.
Paul
