AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
DWG files on Google Drive not found
12 REPLIES 12
Message 1 of 13
garygreen187
3526 Views, 12 Replies
 On my iPad two things happen:
1. When I open ACad 360 and search on my Google Drive folder containing my DWG files, it only lists 100 files, in my case, it lists files starting with O and below, alphabetically.  Tha A-O files are not shown.
2.  When I open Google Drive and search, I find the file but when I try to open it, AutoCAD 360 isn't listed in the "Open With" choices.
Any suggestions?
12 REPLIES 12
Message 2 of 13
garygreen187
in reply to: garygreen187
Any suggestions?
Message 3 of 13
Hi Gary,
Thanks for posting your question to the A360 Forum. You are looking for the AutoCAD 360 forum, so I'll go ahead and move your message.
Hope this helps and have a great weekend.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Autodesk Beta Programs!
Message 4 of 13
pendean
For #2, cloud storage doesn't often work like that from other services either.
For #1, I don't have 100+ files, I do have 40+ folders each with a few dozen files at most and I'm not seeing this issue. 100 sure sounds very definitive, like a max setting somewhere.
Message 5 of 13
garygreen187
in reply to: pendean
Thanks for your response, though it doesn't help.  If Autocad has a solution, I'd like to know about it.  If not, how should I propose an action item for them to fix it?
Message 6 of 13
pendean
>>>...If Autocad has a solution...<<<
AutoCAD is a desktop software.
As a test, put your desired file in a folder on Google Drive then access it from autocad360, can you?
As a test, place your other 99 files on other folders of your choosing, does the problem of autocad360 not finding your files to open go away?
I use DropBox with no isssues, but again, I don't have 100+ files in a single folder, not sure it will solve the problem but worth testing if you already have an account..
Message 7 of 13
garygreen187
Seems to be an AudoCad 360 problem.  I renamed the file starting with the letter z and it now appears in the 100 listed items 5and can be opened.  You're correct that AutoCad 360 seems to have a limit of 100 items, including folders and files.  Assuming each file has an additional .bak version, only a maximum of 50 actual drawings can be shown.  This is a serious limitation.  It would be interesting to open a folder from DropBox or another cloud service with over 100 items to see if the problem is specific to Google Drive.
My other question, regarding Open With remains unanswered.  Looks like Google Drive and AutoCad 360 don't play well together.
Message 8 of 13
pendean
Good test: thanks for sharing.
As far as I can tell AutoCAD360 does not create BAK files in the same folder as the DWG.
"open with" does not exist in the other cloud servers so you'll have to wait for that ability to eventually show up for all of us.
Message 9 of 13
garygreen187
The Google Drive files were created on a desktop PC using Autocad LT 2000 so the bak files are in the same folder.  I use Autocad 360 to access them remotely.
What's the best way to bring these unresolved problems to Autodesk's attention directly?
Message 10 of 13
pendean
You will need to contact the autocad360 team through this feedback@autocad360.com
Message 11 of 13
Hi @garygreen187,
Google Drive app does not recognize DWG files, hence, AutoCAD 360 is not suggested in the 'Open With' dialog box. Known issue on Google's end...
Once you connect your AutoCAD 360 account with Google Drive, you should be able to work on your DWG files within AutoCAD 360.
However, there's indeed a limit for the amount of files that can appear in the Google Drive folder within AutoCAD 360. We're working to increase the current 100 files limit.
Thanks for your feedback!
Best,
Tirza Ben-Ner
AutoCAD 360 Support Specialist
Message 12 of 13
arturonousfd
Hola hasta que puedo ver tu correo gary !
Message 13 of 13
r_baccioni
in reply to: tirza.ben-ner
It was 2017, it’s 2023. And I just discovered that Autocad Mobile for iPad still has a 100 files limit with Dropbox. Meh… trying to work on a train and this made my morning black.
”Boost
