AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Coordinate Conundrum
1 REPLY 1
253 Views, 1 Reply
When using the GPS function in WS mobile, does the drawing coordinate system have to be saved in Lat Long in order to get the device to position me in the drawing automatically . The GPS locates me several hundred kilometers off screen at the moment. I am using the Irish coordinate system ITM.
If required, can coordinate systems of drawings be easily converted?
Overall, the WS mobile app is fantastic.
Tags (1)
1 REPLY 1
dorit_visualtao
Hi Reg, Your drawing coordinate system doesn't have to be in lat and long but you do have to make sure you set your Geo Marker in AutoCAD so there will be a reference point. Also, the GPS uses meters\feet as measuring units, moving on the drawing accordingly. If the units in your drawing are different the result would be inaccurate. For example, if you move 30 meters the GPS will move 30 units in your drawing. If your drawing is in kilometers it will move 30km, if it's in cm - it will move 30 cm. Let me know if you have any other questions. Dorit
”Boost
