AutoCAD on mobile Forum
Welcome to Autodesk’s AutoCAD on mobile Forums. Share your knowledge, ask questions, and explore popular AutoCAD on mobile topics.
Blocks
10 REPLIES 10
Message 1 of 11
1162 Views, 10 Replies
Blocks
Can I create and add new blocks to a drawing or file in autoCad 360 Pro mobile & desktop
10 REPLIES 10
Message 2 of 11
pendean
Not yet, they have to already exist in the file for you to use them.
Message 3 of 11
Disappointed but accept limitations of software. Look forward to a future update.
Message 4 of 11
quicoAdmin
in reply to: pendean
hola,
y ¿qué pasa con los bloques dinámicos?
what about dynamic blocks?
Please report accurately on the use of blocks in the drawings,
thank you very much
Message 5 of 11
pendean
in reply to: quicoAdmin
Not yet.
Message 6 of 11
Macro.Liu_Autodesk
Currently create/add block isn't supported in AutoCAD 360.
For uploaded drawings, the block library contains only blocks that already exist in your drawing.
More details are here: http://help.autocad360.com/customer/en_us/portal/articles/1531775-how-to-insert-a-block.
Message 7 of 11
quicoAdmin
entiendo,
se malinterpretan los bloques dinámicos
pero
¿qué pasa con los objetos de sombreados?
¿y qúe pasa con las acotaciones existentes?
unas se distorsionan (¿hay algún parámetro para controlar su visualización?)
las acotaciones desaparecen
¿hago algo mal? ¿qué me estoy perdiendo?
I get it,
the dynamic blocks are misinterpreted
but
What about hatchs or filling areas?
And what about existing dimensions?
Some are distorted (is there any parameter to control their display?)
The dimensions disappear
I do something wrong
What am I missing?
gracias
Message 8 of 11
pendean
Post a DWG with these other problems, let's all have a look at them.
Message 9 of 11
Hatch isn't supported either at this moment.
Regarding to the dimension issue, it'll be helpful if you can attach a drawing to show this problem. Or, you can submit your question to feedback@autocad360.com within the app.
Thanks.
Message 10 of 11
marci2001
Hey,
the app is still not allowing creation of new blocks, It's been more than a year that it was promised it would.
Anybody could point me to an in-app solution please, or alternatively to how to merge two files?
Thank you,
Marcell
Message 11 of 11
pendean
in reply to: marci2001
There is no change to in-app abilities yet.
”Boost
