Has anyone had problems with A360 showing half the objects in area of the drawing and the other half in another, and some are randomly in different places.
It looks like if you selected half the objects and then just moved and rotated them far away.
Thanks for the reply.
It is the first floor plan i tried.
All objects are in model space and it is a large building something like million square feet.
Its has more than one saved UCS in it the file, not sure why but looks like that half of the objects are translated by that? I just started messing with it and have not looked at point values to see if that was the case.
EVERYTHING is in model space.
In mathematics, translation refers to moving an object without changing it in any other way.
I tried adding a viewport in paperspace to see if that would work but now the drawing will not open A360.
This is quickly not becoming worth it and back to marking up on paper in the field.
