Can anyone please help;
For some time now I have been having problems with folders created online using A360 and the app on my iPad and iPhone. Initially the problem started with a created folder that had files on A360 but not on the app and now any folder created on A360 doesn't appear on the app. I can change and modify existing folders but not new ones. Is there a know problem or is there an upper limit on folder numbers?
Many thanks
Ben
Bud,
Sorry I think I've posted in the wrong forum as I'm using the AutoCAD 360 app (with the red icon). I would be grateful if you could move it across please.
I am somewhat confused and I'm sure I've asked this before but what is the difference between the two? I want to share folders/drawings with customers which is the best app to use?
Many thanks
Ben
Hi Ben,
No problem, we can move this over to the AutoCAD 360 Team.
A360 is for sharing and collaboration, no editing.
AutoCAD 360 is based on AutoCAD and allows editing.
Note that you might be able to find your drawings on the AutoCAD 360 WEB Site if you sign in.
Thanks again for sending in your feedback and hope this helps. I will also move this over to the AutoCAD 360 Mobile site for you.
Have a great day.
Bud,
Thank you for the explanation and I will continue to use AutoCAD 360. Where should I be creating folders and uploading drawings? At the moment I am using the A360 Drive.
Kind regards
Ben
Bud,
Thank you for the prompt replies. To be honest I haven't looked at the A360 app even though I've got it downloaded onto my iPad and iPhone. I actually think it may be better for my clients as the 3D visual display appears to be much better than AutoCAD360.
Once again thank you for your help.
Kind regards
Ben
