AutoCAD 2013/2014/2015/2016
Post 11 of 21
Re: Simple hatching problem on AutoCAD 2013
03-06-2013 09:40 AM in reply to: JDMather
i have this menu up now i do apologize. what to do next?
I can assure you I am studying In glasgow doing building surveying, just finished the CAD unit and I told the lecturer what i was doing for work over the holidays and he suggested using the AutoCAD program for these simple elevations instead of drawing.
Post 12 of 21
03-06-2013 09:57 AM in reply to: JDMather
However i am not finished still need a hand im sorry i really appreciate this JDMather
AUTODESK EXPERT ELITE
2419 Kudos
2044 Solutions
Post 13 of 21
03-06-2013 12:17 PM in reply to: damienloch
damienloch wrote:
Okay so now realigns it was a scale of my drawing problem after using the view all and my drawing was not seen I have scaled it up so that it is now seen once I hit view all.
 Damien Loch
In order to offer instructions on how to fix the drawing - you will need to attach the latest version.
The instructions I will give will be something along the lines of
-set to correct units
-scale if needed to get to correct size
-delete any floaters
-center the geometry about the origin
not necessarily in that order.
Autodesk Inventor 2015 Certified Professional
Using Inventor Professional 2016 Update 2
Highlighted
Post 14 of 21
03-06-2013 02:31 PM in reply to: JDMather
okay here is the attachment.
thank you
Autodesk Support
1 Solution
Post 15 of 21
06-17-2013 11:46 PM in reply to: JDMather
 Can you please elaborate on - dwgunit?
681 Kudos
512 Solutions
Post 16 of 21
06-18-2013 12:57 AM in reply to: damienloch
The main problem in your drawing is not in units, but in fact, that all your geometry is faaaar away from WCS origin.
When I moved everything to near 0,0 of WCS everything is OK with hatches.
I also made some changes in Dimension style.
Maxim
Architect
MARSS
MacACAD | MARSS
2419 Kudos
2044 Solutions
Post 17 of 21
06-18-2013 03:52 AM in reply to: may.anne.ruiz
Not - dwgunit  the command is -dwgunits no spaces and with an s on the end.
Did you read Message #10 in this thread.
Community Visitor
Post 18 of 21
12-12-2013 02:29 PM in reply to: maxim_k
I faced same problem. One of my lines is not accepted as a boundary by the Autocad. When i want to hatch this area, it ignored this line and it accepted upper line as boundary. I controlled elevation or z axis but all the geometry on the XY axes. Is there any way to solve this problem?
2285 Kudos
2046 Solutions
Post 19 of 21
12-13-2013 03:48 AM in reply to: damienloch
Share that DWG file and point to the "line" in question.
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
Community Visitor
Post 20 of 21
12-13-2013 03:58 AM in reply to: pendean
I attached the dwg. If you help me, i will be very happy.
I want to hatch under black level, but it consider only red level(red line), as it can be seen.
