Hi, i am trying to create some things, i am using milimiters and a scale of 1:1 in model (3dobjects) and when i try to zoom in to work in the piece (aprox 20x20x11mm) the grid disappears and the UI starts working a little uncomfortable, for example, if i drag the screen just a little bit the object goes away, is there a way to work more comfortable usign the same scale? because later i will have to do things with those measurements, so it is important to use the real units
Go to Options and turn off the grid while in 3d
mm isn't the problem, your video card maybe.
It is a bit hard to explain, but basically what i mean is that when i pan just a little bit it pans a lot, thing that does not happen when you are zoomed out
https://forums.autodesk.com/t5/autocad-lt-general-discussion/zoom-scroll-increments/td-p/3803145
https://www.google.com/?gws_rd=ssl#q=autocad+pan+increment
Can you attach the file here that exhibits this behavior - there are some other possibilities I would like to check.
