Hello again, i need help with making weld... i have 2 objects which i need weld... how can i extract curve of object interference?
Thx
Solved by ampster402. Go to Solution.
It helps if you make a copy of the original shapes before UNION the parts, use them to SUBTRACT the shape after the weld and you will get the weld.
For example:
But i need curve of those 2 object which is same for both to make print of it... i am sending my triyng file... I have 2 objects... i will substract 1 to have 1 part and from it i need the side tract/plane/area to make 2d for print like there is 1.) Hope u undestand me.)
Okee, If it needs to be rolled out flat (Unfold) autocad is not capable of handling it.
No problem, i have installed inventor too... and there is “unfold“ command or smthing like that? Ty
Here is a screenshot... i added 1 step (third) of deleting areas which i dont need.
