I am trying to set up my own dimension styles but have a reoccurring issue. I will set the scale under the DIMSTY 'FIT' tab to the desired scale, but when I dimension something, it changes sizes. If I go to properties, it shows the Overall Scale as something different than what I set it to under DIMSTY. I have searched high and low for a solution, but have come up with nothing.
I can, but none of them are working properly, so there is nothing to base it off of. No matter what I do, the dimension scales itself however is pleases, and it is not annotative either.
Here is the drawing. I drew a 36" square and dimensioned it twice. One I fixed so it is the correct scale under properties, the other one I left alone.
which one is "fixed" and which one isn't?
Your DIMSCALE variable is set differently for each dimension each (16 and an odd 1.64965123 setting), the larger one is as defined in your DIMSTYLE.
Hopefully I can explain this well. I drew both dimensions at the same time. The text for both of them looked like the vertical dimension; really small.
The one with the text that appears larger is how I would like it to be. It is running horizontally across the screen. I went into the PROPERTIES and fixed the overall scale to 16, which is what I would like it to be, and what it is set to under DIMSTY. But for some reason when I dimension something it changes by itself, in this case to 1.64965123.
I appreciate your help. If you have anymore questions feel free to ask away. I have been trying for a few days to fix this issue.
So with DIMSCALE set to 16 in your DIMSTYLE, I can only create the larger one with any dimension command. Is there something I'm missing? See attached.
>>>...I drew both dimensions at the same time...<<<
Explain.
Okay. You have helped me solve my dilema a little bit. You drew the dimensions and they came out the correct size, DIMSCALE 16. When I do it, they come out to the smaller size, even though DIMSCALE is set to 16. So, it must me something with my schools computers.
Thank you!
