AutoCAD Forum
Circular Viewports
7 REPLIES 7
Message 1 of 8
cmiller
874 Views, 7 Replies
Circular Viewports
I'm loosing my crosshairs/cursor and commands don't work after I've made a circle into a viewport. Anyone else experience this problem?
ACAD 2015
7 REPLIES 7
Message 2 of 8
pendean
in reply to: cmiller
Yes if you are in a layout in a viewport: VPMAX seems to cure it (VPMIN to go back).
Message 3 of 8
cmiller
in reply to: pendean
That does work. However I was making sure that all text and info needed were not out of the circle. Toggeling back and forth can be a work around but I lose the boundaries of the circle. Why not fix the issue?
My text and info is all in model space. I do not annotate in layout.
Message 4 of 8
doben
To see the circle boundary I'd suggest drawing a circle in paper space that matches the viewport then use "chspace" to move it to model space. Put it on a no plot layer or erase it once you're done.
Message 5 of 8
christina.davis
Hi cmiller,
I could not reproduce the lost crosshairs after converting a circle into a viewport.
  • Do you have the service pack: AutoCAD 2015 Service Pack 1
  • GRAPHICSCONFIG>Set Hardware Acceleration to Off. Any change?
  • Does it seem file specific? Can you post a dwg?
  • Any difference if you create a Polygonal viewport using the Arc option?
Thanks 🙂
Please hit the Accept as Solution button if my post resolves your issue.
Christina Davis
Technical Support Specialist
Frontline Technical Support
Autodesk, Inc.
Message 6 of 8
cmiller
in reply to: christina.davis
  • Do you have the service pack: AutoCAD 2015 Service Pack 1  Yes
  • GRAPHICSCONFIG>Set Hardware Acceleration to Off. Any change? That seemed to fix it somewhat.
  • Does it seem file specific? Can you post a dwg?  Only when I have a circular VP. Not sure how.
  • Any difference if you create a Polygonal viewport using the Arc option?  Didn't try those yet.
Message 7 of 8
christina.davis
Hi cmiller,
Is working with hardware acceleration disabled still working for you?
Thanks 🙂
Christina Davis
Autodesk, Inc.
Message 8 of 8
cmiller
@christina.davis wrote:
Hi cmiller,
Thanks 🙂
So far so good.
”Boost
