Hi, I am working on creating title blocks with various orientations for my companies default CAD template. I am attempting to define each title block with attributes that prompt the user to enter the applicable information when they enter that layout tab e.g. "24x36", or "11x17" (or preferrably have a method of sharing user-input data across multiple attributes since they refer to the same things in each title block). The problem is that I have saved the inserted block as part of the standard .dwt and now when I open a new drawing (set to open to this .dwt) there is no prompt to input data for the title block's attributes!
I'm not sure if there is a way to set up a lisp routine to run in acaddoc.lsp that will auto-insert these blocks, but I am open to any solution you may have, the ideal solution being shared attribute data which displays in each title block according to its specifc properties and layout.
Thank you for the help!
