AutoCAD 2013/2014/2015/2016
3 Kudos
2 Solutions
Post 21 of 30
Re: autocad 2013 opening older version
05-08-2013 03:00 PM in reply to: dgorsman
This is what it looks like on AE2014.
Post 22 of 30
05-08-2013 05:20 PM in reply to: ricardo_baez
so now that you can open it, any ideas I can do on the 2013 side of the fence
AUTODESK EXPERT ELITE
1814 Kudos
1258 Solutions
Post 23 of 30
05-08-2013 10:13 PM in reply to: ricardo_baez
When you go into the pagesetup of this layout, what option for "Plot area" is set to be used for plotting, I guess you have set it to Window and not defined the correct window-rectangle? What happens if you set it to "Extents" or "Layout"?
- alfred -
Alfred NESWADBA
816 Kudos
604 Solutions
Post 24 of 30
05-08-2013 10:30 PM in reply to: fiesty
AutoCAD for Mac 2013 also could not open your file, furthermore, after attempt to open this file AC for Mac crashes with CER when I close (quit) it.
When I try to open your file in AutoCAD 2012 for Mac I get a lot of alerts:
First:
Second:
Third:
But then AC for Mac 2012 can open the file.
Maxim
Architect
MARSS
MacACAD | MARSS
3 Kudos
2 Solutions
Post 25 of 30
05-09-2013 07:12 AM in reply to: fiesty
There is definitely something wrong with the file structure. I deleted the layout tab and deleted the contents in model space and I still get an error message when opening the file.
Ricardo
3 Kudos
2 Solutions
Post 26 of 30
05-09-2013 07:30 AM in reply to: fiesty
Attached is a file created in AE2013 by copying the model space contents from AE2014 and pasting into AE2013. Hopefully you can open it.
Ricardo
Highlighted
3 Kudos
2 Solutions
Post 27 of 30
05-09-2013 07:37 AM in reply to: Alfred.NESWADBA
The layout tab page setup shows this:
Then I did this:
Ricardo
1814 Kudos
1258 Solutions
Post 28 of 30
05-09-2013 10:42 AM in reply to: ricardo_baez
please click onto "Modify" in that dialog to come to the pagesetup-details for the layout, that holds the info I asked for. Sorry that I was not clear enough.
- alfred -
Alfred NESWADBA
3 Kudos
2 Solutions
Post 29 of 30
05-09-2013 11:05 AM in reply to: Alfred.NESWADBA
Alfred,
I modified the layout tab to plot a PDF file and selected extents. See image below.
Ricardo
1814 Kudos
1258 Solutions
Post 30 of 30
05-09-2013 11:07 AM in reply to: ricardo_baez
sorry, there is no image attached.
- alfred -
Alfred NESWADBA
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
