This problem shows on:
Symptoms:
Pasting a DWG object or inserting it into another DWG will result in the paste of a different, undesired DWG object (usually a former one).
Tried to clear the clipboard, to install plug ins. Nothing worked.
This is critically blocking, please... help!
R.
Solved by john.vellek. Go to Solution.
Solved by rculp. Go to Solution.
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Does this occur too if you drag and drop a file into another one? Or is this just a clipboard issue?
How are you clearing the Clipboard? Try following these steps.
Does an insert from Design Center work?
Are the drawing files both in 2013 format or at least the same format?
Are you using plain AutoCAD or a vertical product or do you have any add-ins?
Does this happen all the time (even after a re-boot) or just occassionally?
Let''s try logging in as a new user (full admin) to see if this happens with a new account too.
Dear John,
Thanks for your prompt answer.
Please find my remarks below in green.
Best regards,
C.
Very strange behavior spotted while using the drag and drop functionnality:
1). On the work file received from my predecessor: Drag and dropping a DWG will insert another DWG that may exist somewhere in a library, but definitely not the DWG I chose to DnD.
2). On a very new file: whatever the file DnDed, it will always insert the latest copied file... (even if I prior clear the clipboard).
=> I used the very method you advise after browsing forums.
=>Nope, result is the same as a copy paste with this method.
I confirm, all the files are saved in AutoCAD 2013 dwg format.
My AutoCAD 2014 is an official version bought from my company with no add-ins. The AutoCAD 2017 version is the trial version you propose on your website.
All the time.
Let's try logging in as a new user (full admin) to see if this happens with a new account too.
The only conditions in which I used AutoCAD were in "not logged" mode or logged with my only account. Anything I should do to get this "full admin" mode?
Hi @Anonymous,
Please try a Windows Control Panel>programs Repair. Then a Reset Settings to Default. Please let me know if that helps.
As far as the admin permissions, create a new local user account and assign it Full Administrative permissions. Then logon with that account and see if everything behaves normally.
Do you have any add-ins installed?
Duplicate block name??
Is there already a block with the same name as the file in the target file?
HI @Anonymous,
Were you able to duplicate this with a new Windows user account? If this is happening with specific files can you attach some samples to a post?
Hi John,
Could not try yesterday because of other imperatives.
Will try today, thanks for your help, I'll come back to you asap.
So...
Anything esle I could try? Apparently I'm not the only one concerned on the internet but I could not find any decent solution on the fora.
PS: attached are typical files I try to copy paste.
HI @Anonymous,
Inlooking at your files, the first thing I saw was that they were not created in native AutoCAD. I don't know if this is part of the problem or not.
I used EXPORTTOAUTOCAD on both files. Then I checked for duplicates as @rculp suggested. Both drawings had a single block with the same name. I used RENAME in one of the drawings and then I tried the copy and paste without issue. I hope this helps.
Thanks John,
I'll try this next week. We'll be moving to new offices until tuesday.
I'll keep you informed.
Camille
PS: Yes, my dwg files are exports from step files opened (and converted) with FreeCAD .
Hi @Anonymous,
How was the move? I haven't seen a new post so I am hoping you have just been too busy and that the move didn't turn into a nightmare.
Please let me know the status of your issue.
Thanks for inquiring John, I've just settled my office out of the cartboards and should be able to check your advice today.
I'll keep you updated.
Hi John,
Could you please undo your latest modification to this post (posting some answers as solutions)?
=> EXPORTTOAUTOCAD DID NOT do it for me... Defining the resulting files as blocks, changing their names, inserting them in other "AutoCAD certified DWG files" does not work...
Now this issue has consumed too much of my time, I'll find another way to do my work.
Thanks for your help anyways.
HI @Anonymous,
Please take one last look. With the drawings you provided, these are the exact steps I took and then the correct drawing pasted in. The ExportotoAutoCAD is a step I like to take to make sure that there are no strange non-AutoCAD objects in the files. Both drawings utilize the exact same block name. Rename (the block not the file name) it in either one of the drawings to something unique. Then you can paste it into the other. I am happy to provide a video if that would help.
