AutoCAD Forum
Upgrading hardware
5 REPLIES 5
ivantai92
348 Views, 5 Replies
Upgrading hardware
I am looking to upgrade some hardware in my PC. Currently it is running decent but i do notice some lagging in certain area.
Current Setup:
Intel Core i7 - 4770 3.4Ghz
16Gbs of DDR3 1600Mhz
Nvidia GT640 4Gb
dual monitor at 1080p
I know that a lot of people recommend the Nvidia Quadro M2000, but i was hoping if anyone else had a different opinion. I am a college student so i'm on a tight budget but willing to spend extra if absolutely necessary. I was also looking into the Nvidia GeForce GTX 1070 8GB because gaming may happen. I will also be running software like Revit, Solidwork, and Rhino 3D. Along with the typical Adobe editing software.
Thank You
5 REPLIES 5
rkmcswain
in reply to: ivantai92
If you do not have an SSD, that would be my choice for the most bang for the buck.
CPU and RAM are not bad, unless you are going to be doing some heavy work on large models.
braudpat
Hello
For me I will buy a Nvidia GTX 970 AND a fast modern SSD
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
beyoungjr
Very good recommendations here.  The SSD will speed things up nicely but it all hinges on system setup.  Your system isn't bad at all now but I'd bet that you need a "clean out" since you are experiencing lag.
If you go the route of an SSD you should consider a clean install of your OS to the SSD as your primary drive.  If your SSD is large enough you could also direct many of your application installs to it as well but I only have the OS on my C: drive.  I direct my apps to install on 😧 but the various software's still add lots of things to the C: drive just to make things run correctly.
As you look at graphics cards pay particular attention to performance with "Vector" graphics.  Most gaming engines are "Raster" based and the best gaming cards can still perform questionably with 3D CAD work.
Wipeout and reinstall always improves things but its usually a major investment in time!
Blaine Young
Senior Engineering Technician, US Army
john.vellek
Hi @ivantai92,
I wholeheartedly agree with @beyoungjr's analysis.  A good fast SSD in combination with a complete, fresh install will likely speed things up quite a bit.   A newer and more robust graphics card will also be the icing on top. 🙂
John Vellek
john.vellek
Hi @ivantai92,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
”Boost
