Hi, I keep getting the error shown in the picture below, when trying to install AutoCAD 2015 on my laptop. I have no clue what it means so any help is much appreciated.
Cheers. Flynn
>> where do I find this proxy?
In your network, something like the door to the internet.
- alfred -
>> I'm under my step dad's proxy for internet
Then the first way is: ask/inform your dad 😉
>> I found it, but not sure what to do?
change it's settings as described within that article >>>click<<<.
Or disable the authentication need for a short time, run your process and then reactivate it.
Happy New Year, - alfred -
I have the same problem as well. I get an error message stating that the proxy requires authentication.... what should i do to solve this problem? need help urgently ..
thanx in advance
It turns out this message popped up when I allowed my antivirus to block the program called Akamai NetSessions Client.
I went back to the firewall settings and enabled it to access the internet.
Hello @Anonymous,
You may consider trying to reset the internet connection settings. It seems that there may be a connectivity issue.
In the Control Panel >> Internet Options >> Connections tab >> LAN settings >> Do you have automatically detect settings enabled?
7. Temporarily disable Firewall & Antivirus
Let us know how it goes.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
hi im having the same problem on windows 10. i turned off all the proxy settings and also im wondering about the net framework, do i need to have that during the installation? bcs i accidentally deleted it .
