Question: Where can I find the latest list of the Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD?
(List below shown in chronological order - scroll down for the latest solutions posted in 2017.
Click HERE for solutions posted in 2016)
January 2017
AutoCAD locks up when switching between model viewports
Bad quality render when objects are far away from drawing origin in AutoCAD
Copy to clipboard (CTRL+C) does not work in AutoCAD
Edge of viewports plots despite being on a non-plot layer
Excel data link will not insert or update reliably in AutoCAD
How to create a slope hatch in plain AutoCAD?
How to display the AutoCAD drawing setup wizard
Multiple viewports do not display for on a layout in AutoCAD
Points deleted in ReCap reappear when the project is loaded into AutoCAD
Registry key that is set after AutoCAD 2016 Hotfix 4 installation
Spline in DXF file becomes broken when it’s opened in AutoCAD
Unable to add a tangent constraint between 2 objects
Unable to attach a DWG file as an external reference (xref) in AutoCAD
Unable to change layer name in AutoCAD
Understanding purging of an AutoCAD file after copy paste has been done
Using WBlock to write out a portion of your file to a new file in AutoCAD
Viewbase command does not work when a drawing was saved in a newer version of AutoCAD
Where are the automatic save-files saved?
XREF files cannot be edited in AutoCAD
