AutoCAD Forum
Delete ALL “drawing scales”,
51 REPLIES 51
Message 1 of 52
JamaL9722060
10272 Views, 51 Replies
I couldn’t figure out if there is a way to delete all “drawing scales” (attached) in one go. The delete should include all scales even those which are used in the drawing. One drawing scale is required to be kept which is 1:1.
Is that possible
Thank you
Best
Jamal
Jamal Numan
51 REPLIES 51
Message 41 of 52
hmsilva
in reply to: JamaL9722060
@JamaL9722060 wrote:
Thank you Henrique and BeekeeCZ for the distinct effort. It works like a charm
Best
Jamal
You're welcome, Jamal.
Glad I could help, but all credits belong to BeekeeCZ and Gilles Chanteau.
Henrique
Message 42 of 52
JamaL9722060
in reply to: hmsilva
Hi Henrique,
Sorry to bother you again with this issue.
Recently (CAD 2016), the .lsp file that does delete ALL annotation scales in one go appears not to work properly. Sometime, it fails to delete All the annotation scale in one go.
The .lsp file is attached
What might be wrong with it?
Jamal Numan
Message 43 of 52
hmsilva
Hi Henrique,
Hello Jamal,
could you please attach your test dwg?
I don't have AC2016 in this laptop, only 2015, but I think there is no difference in annotation scales from 2015 to 2016...
Henrique
Message 44 of 52
JamaL9722060
Please, find attached the dwg file
Jamal Numan
Message 45 of 52
hmsilva
Hi Jamal,
thank you for the dwg!
I was able to reproduce that behavior.
I have a deadline to meet today, but tomorrow I'll see what I can do.
Henrique
Message 46 of 52
hmsilva
Hi Jamal,
as I had previously said, the problem was not related with the AutoCAD version...
The code was based on a selection of annotative objects, and in your dwg there none of the objects was annotative...
Try this revided version.
Hope this helps,
Henrique
Message 47 of 52
JamaL9722060
Thank you Henrique. It works like a charm
Best
Jama
Jamal Numan
Message 48 of 52
hmsilva
Glad I could help
Henrique
Message 49 of 52
JamaL9722060
Hi Henrique,
It appears that the lps file is again not able to delete some annotation scales. The dwg file is attached
What might be the issue here?
Jamal Numan
Message 50 of 52
nimche
Thanks for all the LSP files and feedback. It does really help.
After using most of the LSP files here and updating the LSP with a newer version provided. I was able to clean one file, but not sure what the sequence is.
Now I am cleaning another file, and the last LSP provided here doesn't clean the scale list. It basically add the 1:1 and I still have 4 to 5 more scale floating around on the list.
Using Architectural Desktop 2017
Thanks in advance.
Message 51 of 52
AutoBIx
in reply to: nimche
I've tried all the lisp and it seems to have a problem with dimensions
If i have a scale set to a dimension and i run the LSP the dimension is forced to 1:1
The multileader keep the scale on but seems the dimension are updated ....
is it possible?
Message 52 of 52
JamaL9722060
in reply to: AutoBIx
We need to wait Henrique to comment on this as her is the creator of the lisp file
Jamal Numan
”Boost
