Hi all,
I need to change my drawing units from inches to feet. For example, when I draw a line and type "100" it spits out a line that is 100 inches long. I need it to be a line that is 100 ft long when I type "100". Basically I need to go from decimal inches to decimal feet. Any help would be much appreciated!
Solved by john.laidler. Go to Solution.
You change the UNITS with the below option, but this will not convert the drawing.
Command: DDUNITS
Thank you for this. I opened the -DWG dialog box and the units were set to mm but the output was some how converted to inches? I'm migrating from microstation and setting these units is something that I find drastically different. I have fixed my problem through the UNITS dialog box and I'm now able to draw in decimal feet.
As a note of caution, most people don't draw in decimal FEET, unless they are surveying or machining. They draw in FeeT-INches (LUNITS = 3 or 4), where a line 100 units long would be 100 inches or 8'-4" long. To draw a line 100FT long you'd draw a line 100' (add the ft mark).
Drawing a line 3FEET 10 and 5/8" long in decimal feet (LUNITS = 2) would require some gymnastics. With LUNITS = 3 or 4, when keying in length simply enter 3'10-5/8 and you get the line precisely that long.
I know I'm the oddball with that ! I keep a conversion chart handy for quick reference so for me it's easier and faster to draw in decimal feet and eliminates the complication of fractions, e.g., instead of typing 3'-10 5/8" I simply type 3.8854' and get the same line with less hassle. To each his own!
That depends on your definition of "hassle". I didn't have to create and keep track of a cheat sheet, or hunt it down when I needed it, or look through it for the number (if your sheet covers 16ths through 1'-0" that's 192 numbers) and then key it in.
3.8854' is 6 keystrokes 3'10-5/8 is 8 keystrokes, but I understand that those two keystrokes are SUCH a hassle and 5/8 is SO complicated, so I can see where you might want to avoid them ..............
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
