When trying to create a data link, my autocad 2017 crashes. It does that after I select the excel file and gives me an message '' The specified excel fil is not valid or not supported'' and then autocad crashed when I click close on that window. I'm the only one in the office that has autocad 2017 and the only one that has this problem. We tried different files and different excel formats and also re-installing autocad. Nothing worked. (I use Excel 2013 and Windows 10)
Welcome to the community!
Sorry to hear about the issue. Only Excel 2000, Excel 2003, and Excel 2007 file formats are supported. You will need to save the Excel file into one of these formats. Open the affected Excel-file in Excel and Save as one of these versions in the save as type section.
A couple of questions here:
Have you updated AutoCAD with the latest service pack?
Could you give us some specs on your computer?
Do you have any customization applied? Lisp routines that run?
Do you have the 64-bit or 32-bit version of Excel installed?
Does this happen with all Excel files, or only some? All drawing files, or only some?
As a test, if you create a new Excel spreadsheet with only a couple of simple cells, and a new drawing from an out-of-the-box template in 2017, does the program still crash every time you try to create a datalink?
See my answers in Italic
Yes
Pocessor : Intel® Xeon® CPU W3680 @ 3.33GHz
Ram : 6 GO
System : 64 bit
Windows 10
No
64-bit
Everything, all the time
Still crash
Could you try creating a new user account (local admin) and logon to windows with that account. Go to Windows Control Panel>Programs, select Excel and do a repair. Next, open an excel file and save it to an XLS format. Open AutoCAD, start a new file and save it as 2013 format. Type datalink and try to browse to the file and then take all the defaults (don't select a range or anything like that).
Did you ever get resolution to this problem? I'm experiencing the same. This is the first time I have tried creating a data link using the 2017 version of AutoCAD and I'm running Architectural.
Hi @slink,
I'm sorry you are having this problem. Please tell me your exact version of AutoCAD by typing ABOUT at the command line. Then tell me which version of Excel you are using and whether or not it is 64-bit.
Also, please, tell me your OS>
Are you trying to create the data link on a network or locally? Can you attach some sample files that you are trying to work with and that exhibit the problem? I am happy to investigate this for you.
Any resolutions on this one? I am having very similar issues today. Trying to create data links in Autocad 2017.1.1, using Excel 2016 32-bit, in Windows 7 64-bit. Data link tool is taking a very long time, and sometimes crashing CAD. I'm able to create a data link, and have CAD recognize updates made in Excel...but I can't get updates made in CAD to upload back to the source Excel file.
Hi @slink,
Can you apply the updates to AutoCAD from your Account page or the Desktop App? Please also, attach some sample files so that I can test on my computer.
HI @mspatafora,
I think that the issue is your Excel is 32-bit. If you have access to the 64-bit version I would like to know if once installed if the issue persists.
Hi Sarah - It came in just fine on my side. I am using 64-bit Excel 2016 with AutoCAD 2017.1.1
Can you verify that your Excel is the 64-bit version please?
Also, you might try adding the link with a range instead of the whole table and then try different paths as well.
is your excel file on your local computer or on the network.
I have similar issues with autocad 2015 and 2016 and the excel file is on the network,I have a data link in a drawing, when I go to edit the link autocad freezes everytime.
if I disconnect from network prior to editing the data link, it works fine. after done editing the link I plug the network cable back in and go about my business.
To answer your initial question - my files are all saved locally, on my desktop.
I actually haven't had much time to play around with datalinks since asking my last question. I did update my Microsoft programs to 64 bit, which I think solved the problem. Again, I haven't fully tested links with the updated Excel, so I can't say for sure whether the problem is fully addressed.
unfortunately, the issue with data link is still there. All your proposed solutions are not helpful. Was it possible for meanwhile to fix this problem?
I am working with Architectural 2016, while up,- downloading xls. files Architectural collapse - fatal error.
Could you help me in this matter?
Sven
@lcaron-lachapelle wrote:When trying to create a data link, my autocad 2017 crashes. It does that after I select the excel file and gives me an message '' The specified excel fil is not valid or not supported'' and then autocad crashed when I click close on that window. I'm the only one in the office that has autocad 2017 and the only one that has this problem. We tried different files and different excel formats and also re-installing autocad. Nothing worked. (I use Excel 2013 and Windows 10)
Hi @sven1510,
I suggest grabbing a trial of current Excel (1026) 64-bit and trying that with your AutoCAD Architecture. When you do this process, try it locally first and then on the network. If you would like to attach some sample files (dwg & XLS) I am happy to take a look
