AutoCAD Forum
Tool Pallette Creation
2 REPLIES 2
305 Views, 2 Replies
I am creating tool pallettes for distribution on my companies CAD Network and am wondering if there is a tool available?  I have used the design centre options and follwed suggestions in the help files, but these don't work at all.
Russ
2 REPLIES 2
rkmcswain
A tool available for what exactly?
You can create a tool palette from a location in Design Center, or you can create one manually.
R.K. McSwain     | CADpanacea | on twitter
pendean
Place your library of blocks on the server, at a location accessed by everyone and in everyone's AutoCAD search paths.
This open ADCENTER as noted above, right-click over each folder in your Library of blocks as noted above to create a Toolpalette of that folder.
You either repeat at each AutoCAD installation, or you export your TPs to external files (also centrally located) and import into the other workstations.
PS: there is nothing wrong if everyone just worked from ADCENTER either: just sort your blocks by type in folders and set the top folder as HOME in ADC.
”Boost
