AutoCAD 2010/2011/2012
1 Kudo
Post 1 of 7
Inserted image is panning badly - *PLEASE HELP*
285 Views, 6 Replies
08-22-2011 05:54 PM
When I pan around, my inserted image fades and only shows the outline of it. I know there's an option to change it somewhere because I've encountered this problem previously. I just can't find the dam thing this time Smiley Mad
It's very frustrating to say the least.
I know it's to increase performance but I need to see it.
I'm running AutoCAD 2012 LT.
If someone could please point out the correct option, that would be amazing.
Life beyond a button to push: the command is called RTDISPLAY and is in LT2012.
11 Kudos
8 Solutions
Post 2 of 7
Re: Inserted image is panning badly - *PLEASE HELP*
08-22-2011 06:10 PM in reply to: Ðomino
Options > Display > Display Performance > Check "Pan and zoom with raster & OLE"
Not sure if this feature is available in 2012LT. Good luck.
Autodesk AutoCAD Map 3D 2016
Windows 7 Professional
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
1 Kudo
Post 3 of 7
08-22-2011 06:16 PM in reply to: grimline
Yup I tried looking in there. Not sure if it isn't included in the LT version or something, but it's not there.
Attached is a screen shot.
Could it be located elsewhere maybe?
Thanks for your help
Highlighted
11 Kudos
8 Solutions
Post 4 of 7
08-22-2011 06:18 PM in reply to: Ðomino
One more thing you could try is DRAGMODE.
8.00 GB RAM
1 Kudo
Post 5 of 7
08-22-2011 06:23 PM in reply to: grimline
Still nothing.
I hope that it is fixable. I've tried using it before and it is painfully annoying.
AUTODESK EXPERT ELITE
2817 Kudos
2296 Solutions
Post 6 of 7
08-23-2011 05:38 AM in reply to: Ðomino
Dean Saadallah
AutoCAD, LT and Architecture User
Blog | Google+ | PINS
Facebook | Twitter | LinkedIn
1 Kudo
Post 7 of 7
08-23-2011 02:13 PM in reply to: pendean
You sir, are a genius. Thanks very much for the help.
Community Alert
The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
Community Alert | The Autodesk Community Forums, Blogs, and Idea Boards will be in read only mode starting on 2/12 at 9PM PST through 12PM PST on 2/13. Please see the following for more information: Site Maintenance Notification
