I draw a lot of electrical wiring diagrams in the automobile industry. Typically I label the wire just above the wire with its appropriate color(s). There are multiple wire colors used in an automobile's harness. I'd like to create a LineType that would display the wire's color(s) using a series of line segnments.
For example a RD/BK (RED with BLACK trace) wire to be displayed as follows:
(where the RED segment is 2X the length of the BLACK segment).
I have created other LineType (acad.lin) using different letters and or numbers, but I'm not sure how to replace those lettrs or numbers with actual colored line segments.
Is it possible?
Thanks for any direction
Dan
Patchy,
Unfortunately our IT / Security Department has that "BLOCKED".
Thanks Patchy!
I'll play around and see what I can some up with.
