I am using Autocad Lt 2014 and am having problems with my graphics. It has broken lines and many other scratchy appearances. I use a windows 7 professionl 64 bit OS Intel R core TM i7 4770 CPU 3.4GHtz. The graphics card is Intel (R) HD graphics 4600. My pc is connected to a network within my company. What graphic card should I be using?
maum
Hi there,
It sounds like it might be a ram issue not a graphics issue. I've been using cad for about 11 years now and I know that it first of all chews up a lot of ram and second will dump any pixels it dosen't need to display an image. My only question is what are you using the image for? If your just using it as reference it should be too much of a problem. Then all you need to do is type in regen in the command line every time you need to see the image clearly. You can also do a print preview to see if the lines will print if you need the image for printing.
Welcome to the Forums
This area of the boards is for full Autocad, BUT try this
Click on TOOLS
Click on OPTIONS...
A dialog box will pop up
Choose the PERFORMANCE tab
Click on PERFORMANCE SETTINGS.
Is "Enable Hardware Acceleration for Better Perfomance" ticked?
Untick it.
PS
Just as a heads up here is the link for the Autocad LT forums
http://forums.autodesk.com/t5/AutoCAD-LT-General/bd-p/43
Howard Walker
