Look at the REGENAUTO command.
From AutoCAD Help:
On:
Regenerates the drawing immediately if any suppressed regenerations exist in
the queue and continues to regenerate automatically whenever you perform an
action that requires regeneration.
Off:
Inhibits regeneration of the drawing until you use theREGEN orREGENALL
command, or set REGENAUTO to on.
If you perform an action that requires a regeneration and that action is
irrevocable (such as thawing layers), AutoCAD displays Regen queued on the
command line.
revocable, AutoCAD displays the following message:
About to regen-proceed?
If you choose OK, AutoCAD regenerates the drawing. If you choose Cancel,
AutoCAD cancels the last action that you performed and does not regenerate
the drawing.
Daniel J. Altamura, R.A.
Altamura Architectural Consulting
and SoftWorx, Autodesk Authorized Developer
DAltamura@compuserve.com
"lukas" wrote in message
news:0B9FEAB470B26638644764891C594132@in.WebX.maYIadrTaRb...
> Can I somehow switch that warning off so Autocad would regenerate every
time
> without asking?
> thx in advance,
> lukas
