Problemas para instalar Revit 2018 no Windows 10
Não aplicável
2.188Exibições
9Respostas
Mensagem 1 de 10
Não aplicável
Não estou conseguindo instalar corretamente o Revit 2018 versão estudante no meu Windows 10. Após concluir a instalação aparece a seguinte janela:20464764_1644396805584167_1505984570_o.jpg
 O arquivo de registro da instalação é esse:
2017/7/19:15:40:34 Vinicius MÜLLER === Setup started on MÜLLER by Vinicius ===
2017/7/19:15:40:34 Vinicius MÜLLER Path_Length: 155
2017/7/19:15:40:34 Vinicius MÜLLER Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_wi_pt-BR
2017/7/19:15:40:34 Vinicius MÜLLER Launch
2017/7/19:15:40:34 Vinicius MÜLLER CommandLine /PK 829J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/Revit_2018_..."
2017/7/19:15:40:34 Vinicius MÜLLER Current Directory C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp
2017/7/19:15:56:24 Vinicius MÜLLER === Setup ended ===
2017/7/19:15:40:36 Vinicius MÜLLER === Setup started on MÜLLER by Vinicius ===
2017/7/19:15:40:36 Vinicius MÜLLER Path_Length: 155
2017/7/19:15:40:36 Vinicius MÜLLER Current Directory C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp
2017/7/19:15:40:36 Vinicius MÜLLER Launch
2017/7/19:15:40:40 Vinicius MÜLLER Download Play SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:15:40:42 Vinicius MÜLLER Download Complete SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:15:40:44 Vinicius MÜLLER Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:15:56:20 Vinicius MÜLLER Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:15:56:20 Vinicius MÜLLER Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp\Setup\RevitSetup.dll
2017/7/19:15:56:21 Vinicius MÜLLER Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/7/19:15:56:25 Vinicius MÜLLER PageOpen LaunchDialog
2017/7/19:15:56:38 Vinicius MÜLLER PageOpen LicenseDialog
2017/7/19:15:56:38 Vinicius MÜLLER PageOpen ProductSelectionDialog2
2017/7/19:15:56:57 Vinicius MÜLLER PageOpen LicenseDialog
2017/7/19:15:56:57 Vinicius MÜLLER PageOpen LaunchDialog
2017/7/19:15:57:17 Vinicius MÜLLER Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp\Setup\RevitSetup.dll
2017/7/19:15:57:17 Vinicius MÜLLER Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=O cancelamento da seleção da instalação co conteúdo irá afetar configurações críticas no Autodesk® Revit® 2018. URLTitle= URLLink=
2017/7/19:16:06:14 Vinicius MÜLLER PageOpen LicenseDialog
2017/7/19:16:06:14 Vinicius MÜLLER PageOpen ProductInfoDialog
2017/7/19:16:06:14 Vinicius MÜLLER PageOpen ProductSelectionDialog2
2017/7/19:16:06:47 Vinicius MÜLLER PageOpen FullProgressDialog
2017/7/19:16:06:50 Vinicius MÜLLER Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:07:02 Vinicius MÜLLER Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:07:03 Vinicius MÜLLER Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:07:35 Vinicius MÜLLER Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:07:35 Vinicius MÜLLER Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Vinicius\AppData\Local\Temp\vcredist_x86_2015.log
2017/7/19:16:07:52 Vinicius MÜLLER Microsoft Visual C++ 2015 Redistributable (x86) return code: 0
2017/7/19:16:07:52 Vinicius MÜLLER Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/7/19:16:07:53 Vinicius MÜLLER Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:08:11 Vinicius MÜLLER Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:08:11 Vinicius MÜLLER Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Vinicius\AppData\Local\Temp\vcredist_x64_2015.log
2017/7/19:16:08:35 Vinicius MÜLLER Microsoft Visual C++ 2015 Redistributable (x64) return code: 1618
2017/7/19:16:08:35 Vinicius MÜLLER Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1618
2017/7/19:16:08:36 Vinicius MÜLLER Download Play DOTNET462 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:09:58 Vinicius MÜLLER Download Complete DOTNET462 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:09:58 Vinicius MÜLLER Installing .NET Framework Runtime 4.6.2: "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\NET\462\wcu\dotnetfx462_full_x86_x64.exe" /q /norestart
2017/7/19:16:11:04 Vinicius MÜLLER .NET Framework Runtime 4.6.2 return code: 0
2017/7/19:16:11:04 Vinicius MÜLLER Install .NET Framework Runtime 4.6.2 Failed Failure is ignored, Result=1603
2017/7/19:16:11:04 Vinicius MÜLLER Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/19:16:15:21 Vinicius MÜLLER Install FaroSDK Succeeded
2017/7/19:16:15:23 Vinicius MÜLLER Download Play RCL http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:15:52 Vinicius MÜLLER Download Complete RCL http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/19:16:15:54 Vinicius MÜLLER Installing Autodesk® Revit® Content Libraries 2018: TRANSFORMS=":pt-br.mst;C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/26:21:17:59 Vinicius MÜLLER Install Autodesk® Revit® Content Libraries 2018 Succeeded
2017/7/26:21:17:59 Vinicius MÜLLER WebInstaller2017/7/28:12:50:49 Vinicius MÜLLER Installing Microsoft SQL Server 2014 (SP1) Express: IACCEPTSQLLOCALDBLICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/28:12:51:21 Vinicius MÜLLER Install Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/7/28:12:51:24 Vinicius MÜLLER Download Play CLMCERT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/28:12:51:25 Vinicius MÜLLER Download Complete CLMCERT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/28:12:51:25 Vinicius MÜLLER Installing Autodesk License Service Certificate: ADSK_EULA_STATUS=#1 MUILANG=pt-br SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/28:12:51:29 Vinicius MÜLLER Install Autodesk License Service Certificate Succeeded
2017/7/28:12:51:29 Vinicius MÜLLER Download Skipped CLM http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/28:12:51:30 Vinicius MÜLLER Installing Autodesk Licensing Manager: TRANSFORMS="C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp\x64\CLM\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/28:12:52:17 Vinicius MÜLLER Install Autodesk Licensing Manager Succeeded
2017/7/28:12:52:18 Vinicius MÜLLER Download Play RVT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/28:13:16:42 Vinicius MÜLLER Download Complete RVT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/7/28:13:16:46 Vinicius MÜLLER Installing Autodesk® Revit® 2018: TRANSFORMS=":pt-br.mst;:all.mst;C:\Users\Vinicius\AppData\Local\Temp\_AI9361.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/7/28:13:24:28 Vinicius MÜLLER Install Autodesk® Revit® 2018 Failed Installation aborted, Result=1603
2017/7/28:13:25:04 Vinicius MÜLLER Rollback Autodesk Licensing Manager Succeeded
2017/7/28:13:25:07 Vinicius MÜLLER Rollback Autodesk License Service Certificate Succeeded
2017/7/28:13:25:15 Vinicius MÜLLER Rollback Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/7/28:13:31:16 Vinicius MÜLLER Rollback Autodesk® Revit® Content Libraries 2018 Succeeded
2017/7/28:13:31:23 Vinicius MÜLLER Rollback FaroSDK Succeeded
2017/7/28:13:31:23 Vinicius MÜLLER Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Dá pra ver pelas datas que mantive a instalação parada vários dias por problemas de conexão, mas justamente pra não dar nenhum problema não desliguei o computador durante o processo, então imagino que isso não tenha afetado em nada.
2.189Exibições
9Respostas
Respostas (9)
Mensagem 2 de 10
clacampos
Olá @Anonymous
Verifique o seguinte:
1 - Se windows esta atualizado.
2 - Entre como administardor
3 - Desabilite anti virus
Em seguida siga os procedimentos abaixo para baixar e depois com os arquivos baixados instale.
1.Tente fazer a instalação fazendo o download pelo Virtual Agent neste link.
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
2. Baixe todas os arquivos (alguns aplicativos somente tem um arquivo único para fazer o download) para seu produto pela primeira vez. Não continue até que todos arquivos tiverem baixado.
3. Navegue até o local da pasta de download e extraia (clique duas vezes) parte _001_00X. SFX. exe (ou o download de arquivo único).
4. Em alguns segundos a extração irá iniciar e solicitar que você extrair para C:\Autodesk.
5. Uma vez concluída a extração, a instalação será iniciado automaticamente.
6. Siga as etapas de instalação para o seu produto
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
0 Curtidas
Mensagem 3 de 10
f_santana
voce tem privilegios administrativos neste computador?
pergunto isso porque segundo a pagina da Microsoft este numero de erro pode ser causado por falta de permissão durante a instalação
https://support.microsoft.com/en-us/help/834484/you-receive-an-error-1603-a-fatal-error-occurred-dur...
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Fábio Santana
Architect | CAD/BIM Manager
0 Curtidas
Mensagem 4 de 10
Não aplicável
Estou passando pelos mesmos problemas e as respostas do fórum ainda não me ajudaram.
Se encontrarem uma solução por favor postem aqui.
Obrigado!
0 Curtidas
Mensagem 5 de 10
clacampos
Olá Guilherme,
Bem vindo a Comunidade Autodesk.
Para podermos ajuda-lo precisamos de mais informações.
Qual o erro apresentado? o problema é ao baixar ou na instalação?
Claudia Campos
0 Curtidas
Mensagem 6 de 10
Não aplicável
Estou com problema na hora de descarregar os arquivos do Revit 2018 versão estudante.
0 Curtidas
Mensagem 7 de 10
RenatoDonatoViana
Olá @Anonymous,
Tudo bem?
Tenta desativar seu antivírus, pois em algumas situações ele estava dificultando o download.
Abraços,
Renato Donato Viana
Você achou esse post útil? Sinta-se à vontade para curtir.
Esta postagem respondeu com sucesso à sua pergunta? Clique no botão ACEITAR SOLUÇÃO.
Mensagem 8 de 10
MatiasWendt
Olá, seja bem vindo à comunidade Autodesk Brasil...
Tente a Instalação de produtos da Autodesk a partir do Agente Virtual:
1. Inicie o AVA (Autodesk Virtual Agent).
2. Selecione o produto e a versão e clique em Avançar.
3. Selecione o idioma do sistema operacional e clique em Avançar.
4. Escolha um método de download e clique nos links apropriados para download.
Observação: É preciso salvar todas as partes do instalador do produto da Autodesk na mesma pasta (por exemplo: C:\Autodesk). Em seguida, clique duas vezes no primeiro arquivo (cujo nome contém 001) para iniciar o processo de extração dos instaladores do produto.
Após o download do software da Autodesk usando o AVA, prossiga com a instalação do produto:
1. Faça login como administrador.
2. Esvazie a pasta TEMP. Para abrir a pasta TEMP, digite %TEMP% na barra de endereços do Windows Explorer e pressione Enter.
3. Desative seu software antivírus.
4. Desative o UAC:
4.1 Painel de Controle de Acesso do Usuário no Menu Iniciar > Painel de Controle > Contas de Usuário e Proteção para a Família > Conta de Usuário.
4.2 Clique no link Alterar configurações de Controle de Conta de Usuário.
4.3 Mova o controle deslizante até Nunca Notificar.
4.4 Clique em OK para efetivar as alterações.
4.5 Reinicialize.
5. Instale seu software da Autodesk.
Importante: É altamente recomendável restaurar o Controle de Conta de Usuário (UAC) do Windows para exibir notificações de segurança.
Se a resposta resolveu o seu problema clique em ACEITAR SOLUÇÃO, isso ajuda os outros usuários a encontrar rapidamente uma resposta, e se gostou, cliquem em CURTIR.
Matias I. Wendt
YouTube | Facebook | LinkedIn | Instagram
0 Curtidas
Mensagem 9 de 10
Não aplicável
Estou com o mesmo problema que o colega relatou, já fiz todo o procedimento acima mas não deu certo. Não consigo instalar o revit!
0 Curtidas
Mensagem 10 de 10
f_santana
Bom, sendo um pouco mais "efetivo"
Se seguiu tudo e estiver realmente com um usaria ADMINISTRATIVO do computador.
Tente baixar manualmente o Microsoft Visual C++ 2015 Redistributable (x64) do site da Microsoft e executar a instalação dele.
Era isso basicamente que LOG de instalação falava que era o problema da pergunta original.
Fábio Santana
0 Curtidas
