Instalar Vault server no Win 2008 server R2 x64
tuliobarata
tuliobarata
Boa tarde, estou tentando instalar o Vault Server 2011 em um PC com o windows server 2008 R2 x64 mas não consigo de jeito nenhum....Ainda estou sem antvirus, desabilitei o firewall, rodei como administrador e mesmo assim não consigo.
Sempre da o mesmo erro na parte do SQL...
esse :
2011/4/1:16:07:06 Administrator SERVIDOR === Setup started on SERVIDOR by Administrator ===
2011/4/1:16:07:09 Administrator SERVIDOR === Setup ended ===
2011/4/1:16:07:08 Administrator SERVIDOR === Setup started on SERVIDOR by Administrator ===
2011/4/1:16:07:49 Administrator SERVIDOR Install ADMS System Check Succeeded
2011/4/1:16:08:31 Administrator SERVIDOR Install Microsoft SQL Server 2008 Express SP1 (AUTODESKVAULT) Failed Installation aborted, Result=1603
2011/4/1:16:09:22 Administrator SERVIDOR Install ADMS System Check Succeeded
2011/4/1:16:10:01 Administrator SERVIDOR Install Microsoft SQL Server 2008 Express SP1 (AUTODESKVAULT) Failed Installation aborted, Result=1603
2011/4/1:16:10:04 Administrator SERVIDOR === Setup ended ===
2011/4/1:16:07:06 Administrator SERVIDOR === Setup started on SERVIDOR by Administrator ===2011/4/1:16:07:09 Administrator SERVIDOR === Setup ended ===
2011/4/1:16:07:08 Administrator SERVIDOR === Setup started on SERVIDOR by Administrator ===2011/4/1:16:07:49 Administrator SERVIDOR Install ADMS System Check Succeeded 2011/4/1:16:08:31 Administrator SERVIDOR Install Microsoft SQL Server 2008 Express SP1 (AUTODESKVAULT) Failed Installation aborted, Result=16032011/4/1:16:09:22 Administrator SERVIDOR Install ADMS System Check Succeeded 2011/4/1:16:10:01 Administrator SERVIDOR Install Microsoft SQL Server 2008 Express SP1 (AUTODESKVAULT) Failed Installation aborted, Result=16032011/4/1:16:10:04 Administrator SERVIDOR === Setup ended ===
eu ja tentei instalar a parte o SQL 2008 R2...e deu na mesma, depois eu tentei o 2008 SP1 e tbm deu na mesma.
Procurei no google mas é muito vago esse erro 1603, é o mesmo erro pra varias causas, ja estou ficando louco com isso.
Se alguem tiver alguma luz, e puder me ajudar..
Muito obrigado
Túlio Barata
IV 2013
0 Curtidas
Responder
443Exibições
0Respostas
Respostas (0)
