2016/4/18:20:11:52 mmarq DESKTOP-OPRBSRO Installing Autodesk Material Library 2017 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{8FB9F735-D64C-4991-8D91-4CDDAB1ABDEE},;;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:12:11 mmarq DESKTOP-OPRBSRO Install Autodesk Material Library 2017 - Low Image Library Succeeded
2016/4/18:20:12:11 mmarq DESKTOP-OPRBSRO Download Play IRONPYTHON
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/IRONPYTHO...2016/4/18:20:12:28 mmarq DESKTOP-OPRBSRO Download Complete IRONPYTHON
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/IRONPYTHO...2016/4/18:20:12:29 mmarq DESKTOP-OPRBSRO Installing IronPython-2.7.3.msi: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:12:43 mmarq DESKTOP-OPRBSRO Install IronPython-2.7.3.msi Succeeded
2016/4/18:20:12:43 mmarq DESKTOP-OPRBSRO Download Play DirectX
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/DirectX_x...2016/4/18:20:12:53 mmarq DESKTOP-OPRBSRO Download Complete DirectX
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/DirectX_x...2016/4/18:20:12:53 mmarq DESKTOP-OPRBSRO Installing DXSETUP.exe: "C:\Autodesk\WI\Autodesk Revit 2017\x64\Tools\DirectX\DXSETUP.exe" /silent
2016/4/18:20:13:01 mmarq DESKTOP-OPRBSRO Install DXSETUP.exe Succeeded
2016/4/18:20:13:02 mmarq DESKTOP-OPRBSRO Installing Autodesk® DYNAMO™ Add-in for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{1EBADAEA-1A0F-40E3-848C-0DD8C5E5A10D},DXSETUP.exe,;;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:13:36 mmarq DESKTOP-OPRBSRO Install Autodesk® DYNAMO™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:13:36 mmarq DESKTOP-OPRBSRO Installing Autodesk® BIM 360™ Add-in for Revit® 2017: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\ProgramData\Autodesk\Revit\Addins\2017\BIM360Glue\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:13:37 mmarq DESKTOP-OPRBSRO Install Autodesk® BIM 360™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:13:38 mmarq DESKTOP-OPRBSRO Installing Autodesk® FormIt 360™ Add-in for Revit® 2017: INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:13:43 mmarq DESKTOP-OPRBSRO Install Autodesk® FormIt 360™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:13:43 mmarq DESKTOP-OPRBSRO Installing Autodesk® Revit® 2017 MEP Fabrication Configuration- Imperial: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2017\Revit MEP Imperial Content\V2.0\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:14:01 mmarq DESKTOP-OPRBSRO Install Autodesk® Revit® 2017 MEP Fabrication Configuration- Imperial Succeeded
2016/4/18:20:14:01 mmarq DESKTOP-OPRBSRO Installing Autodesk® Revit® 2017 MEP Fabrication Configuration - Metric: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2017" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2017\Revit MEP Metric Content\V2.0\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/4/18:20:14:18 mmarq DESKTOP-OPRBSRO Install Autodesk® Revit® 2017 MEP Fabrication Configuration - Metric Succeeded
2016/4/18:20:14:18 mmarq DESKTOP-OPRBSRO Download Play CMILM2017
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CMILM2017...2016/4/18:20:21:18 mmarq DESKTOP-OPRBSRO Download Aborted CMILM2017
http://edutrial.autodesk.com/NET17SWDLD/2017/RVT/WI/{6043D577-637E-4C3F-BA3A-AB7571914E4D}/CMILM2017...2016/4/18:20:21:18 mmarq DESKTOP-OPRBSRO Install Autodesk Material Library 2017 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2016/4/18:20:21:36 mmarq DESKTOP-OPRBSRO Rollback Autodesk® Revit® 2017 MEP Fabrication Configuration - Metric Succeeded
2016/4/18:20:21:55 mmarq DESKTOP-OPRBSRO Rollback Autodesk® Revit® 2017 MEP Fabrication Configuration- Imperial Succeeded
2016/4/18:20:21:57 mmarq DESKTOP-OPRBSRO Rollback Autodesk® FormIt 360™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:21:57 mmarq DESKTOP-OPRBSRO Rollback Autodesk® BIM 360™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:22:17 mmarq DESKTOP-OPRBSRO Rollback Autodesk® DYNAMO™ Add-in for Revit® 2017 Succeeded
2016/4/18:20:22:17 mmarq DESKTOP-OPRBSRO Rollback DXSETUP.exe Failed Failure is ignored, Result=1619
2016/4/18:20:22:30 mmarq DESKTOP-OPRBSRO Rollback IronPython-2.7.3.msi Succeeded
2016/4/18:20:22:46 mmarq DESKTOP-OPRBSRO Rollback Autodesk Material Library 2017 - Low Image Library Succeeded
2016/4/18:20:23:01 mmarq DESKTOP-OPRBSRO Rollback Autodesk Material Library 2017 - Base Image Library Succeeded
2016/4/18:20:23:26 mmarq DESKTOP-OPRBSRO Rollback Autodesk Material Library 2017 Succeeded
2016/4/18:20:23:30 mmarq DESKTOP-OPRBSRO Rollback Autodesk® Personal Accelerator for Revit® 2017 Succeeded
2016/4/18:20:23:34 mmarq DESKTOP-OPRBSRO Rollback Autodesk® A360 Collaboration for Revit® 2017 Succeeded
2016/4/18:20:23:36 mmarq DESKTOP-OPRBSRO Rollback Autodesk Workflows 2017 Succeeded
2016/4/18:20:28:23 mmarq DESKTOP-OPRBSRO Rollback Autodesk® Revit® 2017 Succeeded
2016/4/18:20:28:44 mmarq DESKTOP-OPRBSRO Rollback Autodesk Licensing Manager Succeeded
2016/4/18:20:29:27 mmarq DESKTOP-OPRBSRO Rollback Autodesk® Revit® Content Libraries 2017 Succeeded
2016/4/18:20:29:27 mmarq DESKTOP-OPRBSRO Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2016/4/18:20:29:27 mmarq DESKTOP-OPRBSRO Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/4/18:20:29:27 mmarq DESKTOP-OPRBSRO Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2016/4/18:20:29:27 mmarq DESKTOP-OPRBSRO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
