Assemble Products Forum
Welcome to Autodesk’s Assemble Systems Forums. Share your knowledge, ask questions, and explore popular Assemble Systems topics.
IFC property missing in assemble
3 REPLIES 3
Prajeev.LakshmananCWA5N
699 Views, 3 Replies
When I try to publish IFC from Navisworks to Assemble not all the data coming through.
This is missing
Labels (1)
  • ifc
3 REPLIES 3
Are you able to import the same IFC into Revit and then publish to Assemble from Revit?
@Prajeev.LakshmananCWA5N is your IFC model from either Tekla or Archicad?
if not, then the IFC may only be partially supported and may not "behave as expected" i.e. it may be missing some of its metadata
https://help.autodesk.com/view/ASSEMBLEPRODUCTS/ENU/?guid=Supported_Models
what is the native file format for the model?
also, have you tried publishing said model from BIM360/ACC directly to Assemble?
I am having the same problem, i added properties into an NWD file. The native file i used is IFC. After publishing it to assemble the properties that i added is not captured.
