Assemble Products Forum
Welcome to Autodesk’s Assemble Systems Forums. Share your knowledge, ask questions, and explore popular Assemble Systems topics.
Function to include or exclude linked files in quantity takeoffs
0 REPLIES 0
Message 1 of 1
lee.si.ying
614 Views, 0 Replies
Currently, when I import a model that was published to Autodesk Construction Cloud by the BIM Modeller, I am able to check/uncheck "Include elements in linked files". I need a function where I am able to view what are the linked files, and to select the linked files which I want to include/exclude from the automatic quantity takeoffs. As a Quantity Surveyor, most of us do not have laptops which have the capacity to install Revit, and in my project, the workflow proposed to the client is to import the model published onto Autodesk Construction Cloud into Assemble, we should not be interfering with the model directly to add or remove links in the Revit file. Is it possible to explore this idea?
0 REPLIES 0
