Adding Project Information
staouk
Observer Observer
staouk
Observer
Observer
Hi all,
In there a way to extract the Project Information Parameter Data from REVIT file.  in Assemble Autodesk. Need to link to Power BI Dashboard.  in Assemble Table the parameter does not show. Assemble only show item related Data/parameters
mprobertsMHZTJ
@staouk What type of Project information are you trying to get into Power BI?
If it is only a few details like Project Name, Project Number, Location etc. details that you are wanting to bring in to Power BI to compare data against other Projects' Assemble models, the best workaround I can suggest would be to create custom Assemble Properties so that you can assign those project details to your models, thereby being able to keep them separate/organized when comparing to models from other projects.
Hope that helps!
