Assemble Products Forum
Welcome to Autodesk’s Assemble Systems Forums. Share your knowledge, ask questions, and explore popular Assemble Systems topics.
Accessing property values in offline mode
3 REPLIES 3
kdudek
1461 Views, 3 Replies
When using the Assemble app in offline mode on the I-pad, it is not giving me properties anymore and not allowing me to change installation statuses or add comments. This was available up until a couple of days ago. Is this a feature that was eliminated in offline mode?
3 REPLIES 3
mprobertsMHZTJ
in reply to: kdudek
@kdudek in order for you to be able to access your custom Assemble Properties in the offline mode on iPad, you will need to add all of the properties you will want to edit as Columns in the web browser and save the view with those properties as columns.
Then you will be able to view and edit those properties when in offline mode!
Tags (2)
JuliaAllard
in reply to: kdudek
How can I add the schedule properties as a column to save the view to see and interact with offline?
@JuliaAllard at the top right corner of the model inventory, there is a button for "Columns". You click on that, select which properties you want to be displayed as columns in the inventory (I usually de-select all of the default columns).
Then you save the view. Now, whenever you open that view in offline mode in the iPad app, the columns you selected (and only those columns) will be visible and editable while in offline mode.
