Due to the announced changes for ArtCAM (click here to learn more), the ArtCAM Ideastation was moved to the Read-Only Archive on December 10, 2018.
Option to supress errors when running file converter
An option to suppress or skip all errors would be very useful when using the file converter. Currently when the converter comes to a problem file, corrupt or other, the converter stops until you click ok on the message window. For customers with large amounts of older files, this stall is very costly and forces them to manually remove this file to proceed with conversions.
A check box at the beginning to suppress all messages would be ideal, at the end a summary of files skipped would be even better!
2 Comments
No further development work is planned for the File Convertor add-in compatible with ArtCAM 2015 R2 only.
Status changed to: Archived
