If you do a Ctrl+W in an open model you will find its assigned to "Import Work Planes"
Gary
Ctrl+W does nothing for me. I have ArtCAM Standard 2017 SP2.
What category are work planes in? Is it relief related?
Yep, assigned in legacy ArtCam Pro and ArtCam 2017 Premium
One of those mysterious commands with no listing or reference that I’m aware of, so maybe one of the ArtCam staff will jump in here and correct me.
I think the import workplanes was to import different origins that were set up and saved.
Similar to g-code workoffsets of G54 thu to G59, don’t believe it was ever implemented into ArtCam, thinking it was in Delcam Designer.
As I said one of the engineers should be able to clarify this one
Gary
Hi @Willboyer5985,
Willboyer5985 wrote:I'm trying to assign Ctrl+W to a command (Close Model), but it says it's already assigned. The issue is that it says it's assigned to '????' and I can't add it to any commands.
Many thanks for reporting this issue. As suggested by @Gary.B, this keyboard shortcut was reserved for functionality that has not been implemented. I'll report this issue to the Development team with the intention of enabling the Ctrl+W shortcut to be assigned to a command as part of a future software update. I'll be sure to keep you updated on any progress towards a fix.
Thanks in advance for your patience and understanding.
Kind regards,
