2017.199 premium
Created a Z level roughing toolpath, ran the simulation then lost my toolpath menu
I have had this happen previously but think it was before the SP
thanks
Gary
Solved by dillon.moulder. Go to Solution.
Hi Gary,
Thanks for contacting Autodesk and for sharing your screencast.
I have verified the reported change in behavior in ArtCAM Premium 2017 Service Pack 2 (build 199) at my end. Unfortunately, I was not able to reproduce the problem. Please see my screencast below:
Please follow these steps:
Please confirm whether these steps have resolved your reported interface issue in Autodesk ArtCAM Premium 2017 Service Pack 2 (build 199).
If the issue persists after resetting your workspace, please attach your frieze flourish & ribbon 2.art file or send it to artcam-online-support@autodesk.com so that I can report this issue to the Development team for further investigation.
Thanks for your time and cooperation.
Kind regards,
Hi Prashant,
This is not the first time for menu's going missing by myself and others. A restart of ArtCam clears it and resets to normal.
I suspect this is associated to the missing shape editor reported 2 days ago which Dillon responded to
Gary
Hi @Gary.B,
You're correct. Please be assured that all reports of the issue have been brought to the Development team's attention, and that they are investigating them with the intention of implementing a fix as soon as possible.
Thanks again for your patience and understanding.
Kind regards,
Hi @Gary.B,
Gary.B wrote:This is not the first time for menu's going missing by myself and others. A restart of ArtCam clears it and resets to normal.
The additional fix for this issue is included in the fourth service pack for the Autodesk ArtCAM 2017 product range. Please download and install it, and then be kind enough to accept this post as a solution.
Thanks in advance for your time and cooperation.
Kind regards,
