2017 SP5 Premium
I'm having an issue with the Spin tool creating a column base as follows.
The base has an inside flat diameter of 14.125" and an outside diameter of 17.625" giving a radius of 8.8125". The Profile has a width of 8.125" which should spin to the diameter of 17.625 but it actually spins to 18.6" in diameter.
If I take the matching profile between the inside & outside diameters, 1.75" and extrude it then I get the correct sized profile.
not sure why the spin is larger than the profile.
thanks
Gary
Solved by shirish.bansude. Go to Solution.
Hi @Gary.B,
@Gary.B wrote:
2017 SP5 Premium
Please extend the profile on the right-hand side to the bottom, position it as shown in the screencast below, and then check if this produces the required result; I can see that this cross-section works as expected with the Spin tool:
If the provided information is helpful to you, please be kind enough to click the Accept As Solution button below. Alternatively, reply back to me and I will be happy to assist you further.
Thanks for your time and cooperation.
Kind regards,
Thanks Shirish,
yes I went back and look that at that model over the weekend and found my mistake, when i copied the profile vectors over, the center leg vector was not joined and was left behind, snapping the profile to the center circle I just missed the incomplete profile
thanks
Gary
Hi @Gary.B,
Gary.B wrote:I went back and look that at that model over the weekend and found my mistake, when i copied the profile vectors over, the center leg vector was not joined and was left behind, snapping the profile to the center circle I just missed the incomplete profile
I'm glad to hear that you were able to identify the underlying issue and resolve it.
Thank you for accepting my response as solution.
Kind regards,
