ArtCAM Forum
Welcome to Autodesk’s ArtCAM Forums. Share your knowledge, ask questions, and explore popular ArtCAM topics.
Spin Tool Issue
3 REPLIES 3
Gary.B
394 Views, 3 Replies
Spin Tool Issue
2017 SP5 Premium
I'm having an issue with the Spin tool creating a column base as follows.
The base has an inside flat diameter of 14.125" and an outside diameter of 17.625" giving a radius of 8.8125". The Profile has a width of 8.125" which should spin to the diameter of 17.625 but it actually spins to 18.6" in diameter.
If I take the matching profile between the inside & outside diameters, 1.75" and extrude it then I get the correct sized profile.
not sure why the spin is larger than the profile.
thanks
Gary
Carveco Distributor USA; Legacy ArtCAM Training & Support
Beckwith Decor Products
3 REPLIES 3
shirish.bansude
in reply to: Gary.B
Hi @Gary.B
@Gary.B wrote:
2017 SP5 Premium
Please extend the profile on the right-hand side to the bottom, position it as shown in the screencast below, and then check if this produces the required result; I can see that this cross-section works as expected with the Spin tool:
If the provided information is helpful to you, please be kind enough to click the Accept As Solution button below. Alternatively, reply back to me and I will be happy to assist you further.
Thanks for your time and cooperation.
Kind regards,
Shirish.B
Gary.B
in reply to: shirish.bansude
Thanks Shirish,
yes I went back and look that at that model over the weekend and found my mistake, when i copied the profile vectors over, the center leg vector was not joined and was left behind, snapping the profile to the center circle I just missed the incomplete profile
thanks
Gary
shirish.bansude
in reply to: Gary.B
Hi @Gary.B,
I'm glad to hear that you were able to identify the underlying issue and resolve it.
Thank you for accepting my response as solution.
Kind regards,
Shirish.B
