Solved by dillon.moulder. Go to Solution.
Hi @PLAS1991,
As discussed in this topic, the Development team are working on additional enhancements to the Smooth Relief tool, and I expect them to be included as part of a future software update for the Autodesk ArtCAM 2017 product range.
Thanks in advance for your patience and understanding.
Kind regards,
Hi @PLAS1991,
If you download and install the fourth service pack for the Autodesk ArtCAM 2017 product range, then select the Smooth Relief tool, its settings are displayed on the Tool Settings panel as shown below:
If you click and drag the Strength slider, the value in the Smooth Strength box is adjusted accordingly. Likewise, If you specify a value in the Smooth Strength box, then click Apply, the Strength slider is repositioned accordingly.
After downloading and installing the fourth service pack for the Autodesk ArtCAM 2017 product range, please be kind enough to accept this post as a solution. Thanks in advance for your time and cooperation.
Kind regards,
