Hi @aldaher2020,
@aldaher2020 wrote:
please i need Plasma toolpath and rawter
like old poto i send down
Looking at your screenshot, the ! SINWOO_engraver_ATC_ARC (*.nc) and ! SINWOO_PLASMA_ARC (*.nc) options in the Save Toolpaths dialog's Machine file format list are not associated with any of the default post-processors included as part of the ArtCAM software installation. These options are associated with custom post-processors. You would need to copy the associated post-processor files (*.con) to C:\Program Files\ArtCAM 2015 R2\postp on your computer in order for these two options to be available when saving toolpaths from ArtCAM Express 2015 R2.
If you have any further questions, please do not hesitate to ask. Otherwise, please be so kind as to accept my response as a solution. Thanks in advance for your time and cooperation.
Kind regards,
i dose not found SINWOO_engraver_ATC_ARC (*.nc) and ! SINWOO_PLASMA_ARC (*.nc) options in the Save Toolpaths dialog's Machine file format list
in my computer
please send me that file
Hi @aldaher2020,
@aldaher2020 wrote:
i dose not found SINWOO_engraver_ATC_ARC (*.nc) and ! SINWOO_PLASMA_ARC (*.nc) options in the Save Toolpaths dialog's Machine file format list in my computer
I've previously explained that a custom post-processor file (*.con) needs to be installed to C:\Program Files\ArtCAM 2015 R2\postp on your computer in order for the ! SINWOO_engraver_ATC_ARC (*.nc) and ! SINWOO_PLASMA_ARC (*.nc) options to be available in the Save Toolpaths dialog's Machine file format list. I do not know where you obtained this post-processor file (*.con) from in the past, but it is definitely not included as part of the ArtCAM software installation. I cannot send you the file you require, as I've not seen it before and it is not part of the ArtCAM software installation.
Thanks again for your time and cooperation.
Kind regards,
