When and if we use the software download are the converted files able to be opened on ver 2015?
Solved by dillon.moulder. Go to Solution.
Hi @trkd,
Are you asking whether ArtCAM Model files (*.art) converted in ArtCAM JewelSmith 2015 R2.SP3 (64-bit build 860) using the process documented here are compatible with Autodesk ArtCAM Premium 2017 Service Pack 5 (build 270) and ArtCAM JewelSmith 2015 R2.SP3 (64-bit build 860)? If so, the answer is yes.
If you have any further questions, please do not hesitate to ask. Otherwise, please be so kind as to accept my response as a solution. Thanks in advance for your time and cooperation.
Kind regards,
Hi @trkd,
@trkd wrote:
I was asking if an old file that will not open in ver 2017 after being run with the program you suggested we download will make those files incompatible with the earlier ver 2015. I ask because the 2017 ver has so many bugs that I only use it at home but do not want to make my files only usable in ver 2017.
Since the file conversion process opens and saves ArtCAM Model files (*.art) in ArtCAM 2015 R2, it stands to reason that the files will still be compatible with ArtCAM 2015 R2 afterwards.
Kind regards,
I did find that I could open and older file in 2015, rename it, save as that new name and it is then able to be opened in ver 2017. Thanks for your reply.
Hi @dipeshrudani94,
Welcome to the Autodesk Community and the ArtCAM Forum!
@dipeshrudani94 wrote:
I have a not use artcam 9 pro pls help
(*.art) file open artcam 2017 premium
If you aren't licensed to use ArtCAM Pro 2015 R2, please attach any of the ArtCAM Model files (*.art) that you want to use in Autodesk ArtCAM Premium 2017 when replying to this post, and I'll try to convert them on your behalf.
Kind regards,
Hi @dipeshrudani94,
Artcam 2015 not open because
1 error
As previously requested, please attach any of the ArtCAM Model files (*.art) that you want to use in Autodesk ArtCAM Premium 2017 when posting, and I'll try to convert them on your behalf.
Thanks again for your time and cooperation.
Kind regards,
Hi @rudaniritesh,
@rudaniritesh wrote:
PLS CONVERT (*.ART) FILE ART CAM 2017 IN OPENABLE
PLS OPEN (*.ART) FILE IN 2017 PREMIUM
Please find attached converted copies of your NR 1 TOP FLOWER.art and NR 2 SMALL FLOWER.art files.
If you require any additional ArtCAM Model files (*.art) to be converted, please create and submit a case from your Autodesk Account.
Kind regards,
Hi @dipeshrudani94,
Pls convert the file
Please find attached a converted copy of your nr 2 small flower 2.art file.
Kind regards,
Hi @dipeshrudani94,
how to create case pls help me
As @dillon.moulder has suggested earlier, you can create and submit a case by following the procedure given here, and accessing your Autodesk Account by clicking here.
Thanks for your time and cooperation.
Kind regards,
I upgraded from ArtCam pro 2009 to ArtCam Standard 2018. So I never had the 2015 version, which means I can't convert that way. Surely there's a way to open 2009 files in the 2017 version without emailing it to you.
Hi @ericQ2RDT,
The only other solution is to create and submit a case from your Autodesk Account to request a temporary time-limited PAF Licence file (*.paf) compatible with your existing dongle so that you can download and install ArtCAM 2015 R2 on your computer, then batch convert your own collection of ArtCAM Model files (*.art) by following the instructions in this article from the Autodesk Knowledge Network. If you have any ArtCAM Relief files (*.rlf), you can also batch convert them by following the instructions in this article from the Autodesk Knowledge Network.
Kind regards,
