ArtCAM Forum
Welcome to Autodesk’s ArtCAM Forums. Share your knowledge, ask questions, and explore popular ArtCAM topics.
mill wizard tools
19 REPLIES 19
Message 1 of 20
2994 Views, 19 Replies
mill wizard tools
Using Art cam Insignia Mill wizzard for the first time and I dont see any tools listed?
19 REPLIES 19
Message 2 of 20
OK something weird has happened, I seemed to have lost my tool data base for all my tools now after going into mill wizard
Message 3 of 20
jennifer.dunn
Hi @Anonymous,
That is very strange indeed.
Please try to re-load your Tool Database:
  1. From within the ArtCAM Tool Database, click the Browse button.
  2. Navigate to the ArtCAM Files folder on your desktop, followed by the Tool Database; the full location is as follows: C:\Users\Public\Documents\ArtCAM Files\Tool Database\
  3. Select the tool_database.tdb or tool_database_2015.tdb file, or custom name if you've saved your own.
Hopefully this will re-load the full Tool Database.
Jennifer Dunn
Message 4 of 20
in reply to: jennifer.dunn
Hi Jennifer, Opened up Artcam went to tool data base hit browse to select tool pasted (C:\Users\Public\Documents\ArtCAM Files\Tool Database\) got the tool_database_2015.tdb file  hit the open but nothing loaded
Message 5 of 20
shirish.bansude
Hi @Anonymous,
With regards to importing your Tool Database, this is almost certainly a permissions issue with your Windows user account.
Please check if you have full Administrator rights to the C:\Users\Public\Documents\ArtCAM Files\Tool Database folder, as shown in the image below:
I recommend that you set the permissions to allow writing to the tool_database_2015.tdb file and Tool Database folder, then try importing the same Tool Database, and check if this allows you to import the tools successfully.
You can find instructions on how to change permission here.
Thanks for your time and cooperation. If the provided information is helpful to you, please be kind enough to click the Accept As Solution button. Alternatively, Reply back to me and I will be happy to assist you further.
Kind regards,
Shirish.B
Message 6 of 20
in reply to: shirish.bansude
Hi Shirish, thank you for responding back to me. It looks like I have permission but I am not internally sure how to import the tool list or even were they are? Not that great with PC
Message 7 of 20
mikeis
   Have you tried to reinstall the software?
    Mike
Message 8 of 20
in reply to: mikeis
Hi Mike, Yes tried reinstalling still no tool list
Message 9 of 20
shirish.bansude
Hi @Anonymous,
Thank you for sharing your screenshot. It shows that you do have full Administrator rights on your computer.
There are two locations where the tool_database_2015.tdb file is stored as part of the default ArtCAM 2015 R2 software installation:
  • C:\Users\Public\Documents\ArtCAM Files\Tool Database -  The ArtCAM Files desktop shortcut takes you to this location. Within the list of folders, you'll find the Tool Database folder, wherein the tool_database_2015.tdb file is stored.
  • C:\Program Files\ArtCAM 2015 R2\Exec
Although you only have a C: drive on your computer, please try the steps shown in the following screencast to import the Tool Database:
If you are still unable to import the Tool Database, please use Autodesk Screencast to create and share a screencast demonstrating the issue you've encountered after following the steps in my screencast. This should allow me to troubleshoot this issue further.
Thank you for your time and cooperation.
Kind regards,
Shirish.B
Message 10 of 20
still not getting it , tried the screencast but dont know how to send it to you , I get it to this point I saved it as public but I must have screwed up
Message 11 of 20
If possible can we use something like team viewer so you can access my PC Remotely?
Message 12 of 20
jennifer.dunn
Hi @Anonymous,
Let's try something different.
I have 2 suggestions and I think either will work, it just depends which you want to try. I think you existing Tool Database is corrupt, which is why re-loading isn't working, it's just re-loading the same empty database. Same goes for a new install, as it doesn't replace the old database.
OPTION 1:
  • Uninstall ArtCAM 2015.
  • Using My Computer, browse to the ArtCAM Files folder on your desktop, followed by the Tool Database folder; the full location is as follows: C:\Users\Public\Documents\ArtCAM Files\Tool Database\.
  • Delete the tool_database_2015.tdb file.
  • Restart your computer.
  • Verify that the tool_database_2015.tdb file is not stored within the specified location.
  • Reinstall ArtCAM 2015.
This should install a fresh version of the Tool Database.
OPTION 2:
If you are current with your Autodesk maintenance plan, you can install Autodesk ArtCAM 2017 from your Autodesk Account. From here, you can also create and submit a case, which would allow us to work with you via TeamViewer.
Jennifer Dunn
Message 13 of 20
shirish.bansude
Hi @Anonymous,
If the instructions given by @jennifer.dunn do not resolve your problem, then I have some further suggestions.
When your screencast is uploaded successfully and available for sharing, you should receive an email with containing a link to your screencast with Your Screencast is ready as the subject heading. Please check your email.
Please find attached a Tool Database for you to install on your computer. Please download the Tool_Database.zip file to one of the folders, extract the file, and then try importing to the Tool Database. Please let me know if the Tool List is shown.
Also, although the Tool List is not visible in your Tool Database, the Add Tool button looks active in your 2017-02-17_1037.png screenshot. If you are being prevented from cutting parts on your machine while we're investigating this issue, you can manually add your tools using the Add Tool button, and then use these tools to generate the toolpaths.
Kind regards,
Shirish.B
Message 14 of 20
Hi Thanx for your help but i found the problem and fixed it
Brian
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Message 15 of 20
shirish.bansude
Hi @Anonymous,
Many thanks for confirming that your reported issue has been resolved.
Out of curiosity, and for the benefit of others reading this topic, please confirm what process you followed in order to resolve this issue.
Kind regards,
Shirish.B
Message 16 of 20
I simple went into to programme itself and asked to find the toolbox and opened it
Message 17 of 20
shirish.bansude
Hi @Anonymous,
Thank you for confirming that the Tool Database file (*.tdb) has successfully been imported.
Kind regards,
Shirish.B
Message 18 of 20
Hi
I am having the same problem with Artcam standard 2017 will the above advise work for this version also
Bill
Message 19 of 20
shirish.bansude
Hi @Anonymous,
I'm not exactly sure what problem you've encountered, as you have not provided any details. That said, if any of the provided workarounds seem applicable to your problem, please try following the given instructions and let us know whether the problem has been resolved.
If it does not, please provide a detailed description of the problem that you've encountered in Autodesk ArtCAM Standard 2017.
Kind regards,
Shirish.B
Message 20 of 20
Dear,
Thank you very much for your support about Tool Database link.
I was in trouble.
Thanks again
Regards
Muhammad Farrukh Nadeem
