I am looking for a program to use for machining complex triangle meshes with my CNC router. I'm currently looking at ArtCAM Standard. I have Fusion, but it seems as though fusion doesn't like Highly detailed STL files. Will ArtCAM struggle with generating toolpaths on a file like this?
Solved by dillon.moulder. Go to Solution.
Hi @Anonymous,
Welcome to the Autodesk Community and the ArtCAM Forum!
You can compare the different products in the Autodesk ArtCAM 2017 range here.
You can import a triangle model (including STL files) into Autodesk ArtCAM Standard 2017 using the Relief > Import > Import 3D Model menu option, paste it into the model, and then create a Machine Relief toolpath to machine the relief. The model resolution in Autodesk ArtCAM Standard 2017 is restricted to 2000 x 2000 pixels, so this should be considered if you intend to work with high-detail triangle models.
You can download a 30-day trial version of Autodesk ArtCAM Standard 2017 from the ArtCAM website. This is available for Windows 64-bit only, and the system requirements can be found here.
When installing, please right-click the downloaded Autodesk_ArtCAM_Standard_2017_R1_Multilingual_Win_64bit_Setup.exe file, then select the Run as administrator context menu option. The downloaded Autodesk_ArtCAM_Standard_2017_R1_Multilingual_Win_64bit_Setup.exe file is 749 MB (785,506,304 bytes) in size on disk.
If you have any further questions, please do not hesitate to ask. Thanks in advance for your time and cooperation.
Kind regards,
I want to machine this outrageously detailed model that I spontaneously purchased off a guy who said it can be cut in ArtCAM or Aspire. I've only worked with vectors and parametric modelling in the past, and have never had to consider pixels. At 2000 x 2000 pixels, if I make this model 20 inches tall, will my accuracy be within +/- 0.010" on the surface? I can work with that. Unfortunately, I can't download the ArtCAM trial until I pick up a new PC.
Hi @Anonymous,
browellr wrote:I want to machine this outrageously detailed model that I spontaneously purchased off a guy who said it can be cut in ArtCAM or Aspire. I've only worked with vectors and parametric modelling in the past, and have never had to consider pixels. At 2000 x 2000 pixels, if I make this model 20 inches tall, will my accuracy be within +/- 0.010" on the surface? I can work with that. Unfortunately, I can't download the ArtCAM trial until I pick up a new PC.
Looking at your supplied image, I'd suggest that Autodesk ArtCAM Premium 2017 would be better suited for your job as you would have a greater range of toolpaths and machining strategies available to you. That said, I do recommend that you download the trial version of Autodesk ArtCAM Standard 2017, import the STL file into a model with the maximum resolution, and then create your Machine Relief toolpath using a high Tolerance. If and when you attempt this job, the Autodesk Community will be available to assist you further.
In the meantime, if you send the STL file in question to artcam-online-support@autodesk.com, we can investigate further on your behalf.
Kind regards,
